Yea, it seems that you change them out like that. The bottom, black plastic part is even swappable. You'd just have to drill the hole for the turn signal, where as on the ones that are "turn signal mirrors", the hole/socket for the bulb is already there.
How to take off the mirror:
http://www.youtube.com/watch?v=fEIh76Slfhw
I made it for someone wanting to see the motor, but you can see what I assume is the turn signal spot, next to the puddle lamp spot. Either way, it's easy to take out (even has a handle on the side). If you want to take off the bottom part, it's held by pressure clips and two (maybe three) torx screws. Should be evident if you start poking around.
