LED light swap
ELVATO
Orlando, FL
Hell yeah, why spend $10 for one bulb when you can buy 10 for that price and have spares... Hehehe
My philosophy... Though I'd assume mine count as a mid point as far as price goes.
I'd consider mined to be decently bright.
FtLaudBlkGT
FtLaudBlkGT
I really don't want anything real blinding either...
NewbieVet
Knoxville
Yea, it seems that you change them out like that. The bottom, black plastic part is even swappable. You'd just have to drill the hole for the turn signal, where as on the ones that are "turn signal mirrors", the hole/socket for the bulb is already there.
How to take off the mirror:
http://www.youtube.com/watch?v=fEIh76Slfhw
I made it for someone wanting to see the motor, but you can see what I assume is the turn signal spot, next to the puddle lamp spot. Either way, it's easy to take out (even has a handle on the side). If you want to take off the bottom part, it's held by pressure clips and two (maybe three) torx screws. Should be evident if you start poking around.
What gen expy was this? Assume it's the same on all of them? I need to pop my right side mirror and turn it around cause the guy who had the truck before me must have broken it and bought a replacement, but when he installed it he did it backwards with the wide part of the mirror on the outside and the thin part on the inside (in other words backwards).
