Hello Community!
Has anyone had luck using LED switchback bulbs in their front turn signals in the 3rd Gen Expys?
I did a full LED exchange on my 2017 Expy but cannot get the front switchbacks to operate correctly. I did research this prior to purchase and install, and did not find much about issues, so I assumed it must be viable.
After install and Forscan update (hyperflash off), the bulbs still exhibited hyperflash unless the running lights or headlights are on. A further search suggested that resistors may still be needed, so I installed them too. Same thing, hyperflash only when running lights or headlights are off.
The odd part is that with the truck off but accessory power on, the bulbs behave correctly. In this situation, all of the lights are off, ie, no running or headlights on. With the truck running, everything else being the same, I get hyperflash. Again, they operate normally with running lights or the headlights on, but not if all the lights are off. They only work correctly if the truck is off, the lights are off and accessory power is activated.
Everything shows correct in that Forscan module. Is there a solution to this or do I just get yellow LED turn signals? I find it very strange that it works correctly with the truck off, but not if it is running, but then again, I am not a Ford engineer.
