Limited - Ambient Lighting Not Showing in Sync
Yaady
SoFla
Yep. They removed the option on the limited. Just 1 color.
Sent from my iPad using Tapatalk Pro
Thanks for the reply I’m a newbie here. Let me guess no way to get the colour options back.
LokiWolf
LokiWolf
Moderator
Richmond VA
Not without swapping all the actual light modules out.
Yaady
SoFla
Hmmm something to think about. Only to get it and use it once. Lol.
Do you know if the 18’s & 19’s came with colour options
TXFRDOwner
On the F-150 forum I’ve seen it to where they just swapped out the LEDs for 2017 ones and they got the different colors to work
mpc11
MI
Yes. At least the '18 Limiteds do.
LokiWolf
LokiWolf
Moderator
Richmond VA
Correct, you can swap the light modules(A little more than just an LED) out to the 2019/2018 part numbers. Mine at least has the controller for doing the color changes, but at some point based on my research the 150's changed over to a controller that can't change. So if they do that in the Expy you would need to swap that too. Just not worth it for me...does slightly bother me though.
LokiWolf
LokiWolf
Moderator
Richmond VA
Just an FYI - on my 19 after upgrading to sync 3.4, I can still change the colors.
Originally we thought it might be software related. Confirmed pretty quick that was not the case.
DWs-TTEB
Evans, GA
Ice blue is my color of choice in mine. It matches all the lights on the steering wheel & cell charging station.
dlcorbett
Air Force
tx
Purple was my color, with bmore raven headrest covers and mats
Rob6805
My 14 Flex had different colors to choose from. Kinda cheap of Ford to remove this option.
