Limited - Ambient Lighting Not Showing in Sync
VBreithaupt
Does anyone know if there is a setting to have the ambient light on while you are driving? I couldn't find any threads. Currently mine only comes on when I turn the vehicle off to get out, then all the ambient lights come on, cupholder door panels, second row under sheet? It would be nice if the cupholders light stayed on or the door lights while you drove? I have 2020 Expy max limited. Thanks
dlcorbett
Air Force
tx
It's probably different than when I had my 18 amd now current 20 nav since they did away with the colors, but whenever the lights went out, on the screen where you would select the color, if it was off the color pallettes would be on the lower row, when you re-elected the color, it would move up and the lights turned on.
m3olsen
CNY
Someone with Sync 3 will need to chime in for the location of the setting (I'm now on Sync 4A and don't remember where it was in Sync 3, but @VBreithaupt you CAN have the ambient lighting on while driving. My 2017 Limited and 2022 Limited both did/ do. It will be in your Sync menus. I'm just guessing now, but possibly you just need to pick a color to enable it.
VBreithaupt
I found the problem, the ambient light setting was turned all the way down. Seems to be working now. Good to know. 2020 don't have the color choice like the rest of you high rollers!!!:)
