Long Crank !!!!! Help !!!
Spicoli
Florida
Ok, I have read all the other posts, but no help...I have a 2004 EB 4.6 Expy with about 86,000 miles. All of a sudden I tried to start it one day and it didn't start the first try as it usually did, and it has been doing it for over 2 months...When I turn the key and crank for 2-3 seconds it dosen't start, I let off, then crank again for about 2 seconds and it starts (although it sometimes runs rough for about 2-3 seconds after it is started, then it smooths out and runs fine)...The first thing I did was change the fuel filter, didn't help...I checked the air filter (like new). I changed the spark plugs, didn't help. The battery checks good and cranks strong. It runs excellent even at full throttle and idles great(except where previously noted). It doesn't blow any smoke out the exhaust when it does finally start up. I tried turning the key to just before the starting position and let it set there for 3-5 seconds before cranking, but that does nothing to help. I have tried different brands and octanes of gas, and have ran fuel injection cleaner through it twice. I really do not want to take it to the dealer, so any help would be appreciated. Thanks...P.S. once in a while it will just start the first try, but probably only once in 35-45 starts.
green03
College Station, TX
replace the IAC..... This is a valve that regulates idle speed by varying airflow into the engine. I am 99 percent sure this is your issue.....
Matt R
lakmflx
P.C.B
Sounds just like it to me... Its about 55-60 bucks to replace but a little of a pain to change since it sits right at the firewall. If i remember correctly there are 2 8mm bolts holding the IAC in. Basically what you are looking forward too is some free time, a few scraps here and there on your hands and patience.
One last thing... may want to use sockets that lock into the ratchet or those ratchet wrenches cause if this is the first time you will be doing it i can guarantee you that you will drop tools and then the fun really begins trying to find them and getting them out. Just a note of caution but nothing to be scared about.
JUST4FUN
Admin
Moderator Administrator
Il
Pull the vacuune line off the fuel pressure reg and make sure its not leaking gas into the vacuume line
S
Spicoli
Florida
If the IAC was the problem, wouldn't it give a code...I went to Auto zone and they put the code scanner on my truck, all good, no issues..??
green03
College Station, TX
nope... there isn't a position sensor on the IAC.... The computer just tells it what to do and doesn't know if it is really doing it or not..... The computer can detect a shorted or open winding in the magnetic coil that drives the valve but that's it.
The symptoms are stalling when cold and all of the sudden when running rough it just "pops" back to a good idle.....
Matt R
AvroAero
Toronto, Ontario
If I have a slightly rough idle sometimes when the truck is in drive and stopped, could it be the IAC? Its more common with the AC on.
green03
College Station, TX
Yes this could be your issue..... also if your air filter gets pretty clogged up it can do this too.....
Matt R
JUST4FUN
Admin
Il
Is there a check valve in the fuel pump? thats letting the gas drain back?
green03
College Station, TX
Not if the truck is running.......
It maintains fuel pressure at all times with the engine running.
If the computer can't add enough idle speed via the IAC it will resort to adding timing to increase the idle speed which will give the engine the shakes. I have even resorted to changing some of the parameters on my custom tunes to allow the IAC to give more airflow that seems to smooth out the shaky idles that some trucks seem to have bone stock.
Matt
pepelepuu
orlando, florida
Does anyone know if the IAC was the trick
Spicoli, was the problem the IAC? My 04 Expedition is experiencing the very same symptoms
S
Spicoli
Florida
Response
It ended up being a bad check valve on my fuel pump. I hooked up a fuel pressure tester, and as soon as I shut my engine off the pressure went to zero. The lines are supposed to stay pressurized so fuel will be readily available when you go to start it. Try turning your key on for a second or to then back off three times and try to start it then, if it starts right away this check valve could also be your problem. Hope this helps, Let me know what you find out....
jj1234
Phoenix, AZ
Where is the check Valve
I have a V8 5.4L with the same problem long cranking. It use to start up fast. Where is this check valve located? How do I replace it?
S
Spicoli
Florida
Check valve
Check valve is part of the fuel pump assembly, new fuel pump is about $275.
AW_3_3
Upstate New York
The fuel pump if memory serves, is also inside the fuel tank in most cars nowadays, inaccessable to all but the most experienced mechanics. Definitely a job for the Dealer.
davesexplorer
Berrysburg, PA
First, I did laugh at your thread title. I believe the pump is in tank in that you would have to drop the tank, bring it out from under the vehicle and swap pumps. I've not had to deal with that yet that's just what our service guy said about our fleet expeditions.
jj1234
Phoenix, AZ
Thanks for the fuel pump check valve information. The problem to my vehicle was the fuel filter and that fixed the starting problem, but starts runs sluggish after driving for a long time. Any ideas?
yelgnissm
Philippines
I'm having the EXACT same problem
Did cleaning or replacing the IAV fix the problem? It's the next thing I'm going to check.
M
Temple, Georgia
Go to the dealer to replace a fuel pump?
NEVER IN MY LIFE TIME
Two sets of jack stands, good floor jack, set of fuel line disconnects and we are off to the races...
