Mishimoto IC and Radiator
OGBobbyJohnson
sebring florida
Anyone in here running Mishi IC and Aluminum radiator? I upgraded to the garrett powermax turbos and they are producing more heat of course. Live in FL so need to keep it cool. Coolant spiked to 245 and IAT to 120 yesterday with it 91 degrees outside. i did figure out we used pure antifreeze when we swapped the water pump for 2nd time in 6 months so drained the tank and have it closer to 50/50 mix now. brought it down about 10-15 degrees. Towing my 33' RV in two weeks to softball world series in Viera and cant have any issues.
JasonH
Houston, TX
Try the searching one of the F150 forums. There are more of those on the road, so you're more likely to see experiences with those parts. I think Full Race has upgraded intercooler and radiator as well.
@Ellison Brown III used upgraded Full Race parts on his vehicle. I don't recall which parts, but Full Race might have some insight into what parts may fit properly. You can also try going with a colder thermostat. Good I was considering the Powerboost upgrade as well, because I think 90% sure I have a leaking manifold.
Hvunderground845
North Carolina
I'm finishing installing my powermax turbos now, and crp manifolds. Had 2 turbo bolts break while removing but all manifold bolts came out easier than expected
I have a mishimoto intercooler, trans cooler, and coolant reservoir installed already, I have the radiator and thermostat waiting to be installed. Eventually lol I have alot of aftermarket stuff wired up and have been putting it off cause I'll have to take all those wires out of the way. Did you ever install your mishimoto radiator?
