New guy here,clicking sound
stangdad
brandon fl
Hi guys. just pick up a 98 expedition eb, I keep hearing a clicking sound in the rear by the sparetire, is there a relay in there?
thanks you for your help:rolleyes:
sngltrck1
Arizona
While holding still / engine on?
Any change with acceleration or braking?
Do you have air bags in back?
stangdad
stangdad
brandon fl
seems to be after i shut it off. and last about 5mins then you don't hear anything. no change everything else ok
ssbroly
Ohio
If it's got an air ride suspension, you can usually hear the solenoids on the air bags, otherwiseit may just be the exhaust cooling off. Other than that, no ideas.
sngltrck1
Arizona
Yep ... that's why i asked about the air bags.
Also - a leaky fuel injector will cause the pump to turn on keeping the
pressure right in the lines. Hmmmm, not for 5 minutes though probably.
The tow package includes some relays back in the rear panels by the jacks and stuff. Is your tow harness connected?
The exhaust pinging as it cools down is the only noise my expy makes
back there! However, I have a friend who works on fords and I will inquire
if he has any ideas.
ssbroly
Ohio
I wouldn't be too worried. My Expy's always tingin and pingin when I turn it off. Doesn't last long at all.
stangdad
stangdad
brandon fl
I crawled under after parking and it sounds like the solenoids on the airbags.
Thanks Guys
Jefes_Shyt
