IMINYOURCHAIR
Hi, My name is donald, I work on cars and now trucks as a hobby so to speak, I'm coming over from a 2004 Volvo xc70 that has too many problems to mention. I just bought a '97 xlt with the 4.6 for a steal at $400. The interior and exterior are beat though but I plan to improve that soon. but first there are the kinks to be worked out of her. as I shall mention below.
First off, there is a coolant leak. I suspect the intake gasket as it pools in the valley just under the intake. (anyone have any suggestions for the repair?)
second, it is missing horribly but I suspect it just needs a good tune up. as the wires look horrible.
the steering is wicked loose but I found the arm that connects the steering box to the linkage to be worn where it connects to the bar.
the PO removed the ac compressor. I suspect the bearings went out. they replaced it with a pulley and didn't plug the hose ends
the washer fluid bottle doesn't hold fluid...rather it leaks into the pass floor and pools just under the door. How..IDK. I know it's not the heater core because I poured orange fluid in the washer bottle and green antifreeze into the coolant. Possible that a feed hose to the rear is busted? I haven't looked yet.
the headlights are horrible. they aren't hazed but the light seems to scatter instead of being directed to a usable beam...
the IP lights are allmost all blown out.
so far I have already had to replace the two quick connects for the rear heater core. they were the reason the truck was parked to begin with I suspect. Tomorrow I will go pick up the plugs/wires and try to start on that
a bonus to the deal...When I arrived the first thing I noticed was the ass end sagging. but after fixing the tire pressures ( it needs a whole new set, spare included) and running it a half mile the rear leveled out. when I asked about it I was told it had new rear suspension air bags included, front/rear brakes, new brake fluid, new alternator, new water pump/tstat. all the parts he listed looked new and their fasteners looked like they had been removed recently due to a lack of dirt. the CEL light was on for the mentioned mis-fire. the exhaust smelled fine and it seems the cat converters are doing their job. I also checked the upper corners of the windshield and it seems like the seal is either fixed or isn't failing.
I will try to keep this updated as I fix all the problems. Wish me luck.
