I'm trying to figure out if my new used EPAS is really DOA or if it's something else. My original one was destroyed and I finally got around to installing one from a 2017 Expy that I picked up in August from a local salvage yard. I saved the original abt file for the SCCM and VDM for my Ex using Forscan. After I installed the used epas unit, I uploaded and saved the as built file, but it said nothing was changed. I forced the update like it requested. That could be because it came from the identical vehicle I suspect. I started the Ex and no power steering. I ran the tests on Forscan and it said no errors with the system, but I do still have a couple of DTCs.
It's possible the harness took a hit too, so I'm going to replace it with the one that came with the new rack. In the mean time, any thoughts? Thanks.
RCM: All the "full from accident" codes. Still need to have it reset for the new belts and bags.
SCCM - No dtcs
VDM:
U0126 - Lost Communication with Steering Angle Sensor Module (dtc present at time of request)
IPC:
U0131 - Lost Communication with Power Steering Control Module A (dtc present at time of request)
ABS:
B1596 - Service Continuous Memory dtcs (Not present at Time of Request)
ABS:
U0131-E0 - Lost Communication with Power Steering Control Module (dtc present at time of request)
SCCM - No dtcs
VDM:
IPC:
ABS:
ABS:
