Newer Spark Plug Heavily Corroded
Hoos95
2007 Expedition EL 2WD with only 348K miles.
Around 6,000 miles ago new spark plugs and coil packs were installed. Yesterday the idle and ride got very rough - bad shaking and significant loss of accelerating power. Check engine light started flashing and then solid. Went to Autozone for diagnosis which determined a misfire in cylinder 1 - in hindsight probably the best cylinder to have an issue.
Pulled the coil pack and then removed the spark plug; the plug was so heavily corroded and the worker said the plug was “f’ed”. Replaced the plug and driving is back to normal.
Obviously this is concerning that a new plug would be in this condition only a few thousand miles after install.
What could have caused this?
FYI, the head gasket is bad and will be replaced soon, if that has any relation.
Traveler
Mesa AZ
A bad head gasket can allow coolant to leak into the combustion chamber, which can wreak havok in all kinds of ways.
Sent from my moto g(7) optimo (XT1952DL) using Tapatalk
762mm
Quebec, Canada
Obviously the coolant is getting into that cylinder and corroding the plug...
762mm
Quebec, Canada
Where's the corrosion? Looks to me like there's just some burnt brownish carbon deposits on it.
All plugs you pull out of an engine will have brownish deposits on them (caked in burnt gas + a bit of burnt oil that gets through piston rings). Your old spark plug looks fine externally, it's more than likely your plug coil that was causing the misfire...
Here is a used / new spark plug comparison from when I did mine a few weeks ago :
H
Hoos95
Ran the scan tool and got these pending codes: P0354 (coil D) and P0358 (coil H). So to 762mm’s point, could the new coils be causing an issue not related to how the spark plug looked?
762mm
Quebec, Canada
If you put cheap (Chi-com clone) coil packs in there, then it is very likely. Some people get lucky with aftermarket, but most recommend to install only Motorcraft coils on Ford engines. Even so, you can still get a dud or two... I hope they are still under warranty.
If you still have the old ones, swap the new that are acting up for the old ones and see if the problem goes away. It takes 2 minutes to do...
As a rule of thumb, when changing these, you should always keep the old ones that weren't acting up (for future troubleshooting purposes and as emergency spares).
TobyU
Ohio
That plug looks fine and normal.The brown area is where the carbon builds up as part of the poor design ford did and what causes them to stick and when they were 2-piece, leave the bottom half stuck in head.
But that should not be causing the misfire.
P0354 very well might be a coil fault.
Normally is the coils are good and a plug is misfiring or even if a coil is breaking down you will get a P0304 for #4 and them sometimes you will get an 0354 or other generic misfire code along with it.
I don't like it when people slam the cheap ebay coils!
Have you personally had any failures? How many out or how many and at what miles?
I have had NOTHING but excellent results form them. My first set bought in 2008. Had two of those eventually swapped out with other ones for random misfiring but that was after 8-9 years and no plug changes.
I didn't even change the plug when the cyl misfired. Just slapped a good used coil. The gap could have been really wide and the coil just couldn't fire that wide. But still excellent results from them.
I have used 6+ sets on other cars and haven't had any other fail yet.
The most recent set purchased this March so this is not to say that the newest ones are as good as the ones I have been getting over the last 11 years but we will see.
At under 5.00 each. It's going to have to be a very short life to make me pay more for them.
762mm
Quebec, Canada
Nope, I have no experience with them. Probably never will, since I plan on buying Motorcraft the day mine fail. Murphy's law : if the cheap ones are a dud and fail, they will fail at the worst possible moment, lol! Personally, I'd rather not take the chance... even if it saves me $100 or whatever.
I just wrote what MOST people report, including Ford Tech Makuloco on YouTube. I have also read some reviews on Amazon and they've been not all that great. I do recall some folks here (including you, I think) saying to have had good luck with the aftermarket ones, which is why I also mentioned it.
Finally, barring manufacturing defects, the spark plug gap being too wide is what primarily kills the coils on modern engines. A wide gap forces the coil to work a lot harder, thus burning it out. That's another good reason why I put properly gapped iridium spark plugs in my engine (electrodes don't burn on them and the gap stays the same for ages).
TobyU
Ohio
I wasn't aiming at you particularly, just saying that when people talk bad about coils but they have not personally had any failures it's really not accurate to base decisions on that.
I completely agree about the plug gaps and that's why I mentioned it with the ones I had that misfired intermittently. If I'd actually changed the plugs or maybe just put a new plug or even regapped the plug in that cylinder it might have not misfired but I had good used coils laying around here and when I stuck one in the misfire went away. That was easier than removing the plug.
I won't buy or use iridium plugs because they are overpriced and I really don't need come to last that long. I don't want any plugs to be in an engine for a hundred thousand miles even if they have zero Gap erosion.
I stick with a standard platinum or sometimes a double platinum plug.
I will say, not on automobiles, but I have had at least one specific instance on a high-performance older carbureted motorcycle for everybody and plugs just did not work.
Despite the fact they are better plugs for longevity they seem to be a lot like the original boss platinum's. They tend to foul out and don't like oil either.
The motorcycle had a freshly rebuilt engine and I've been running fine with those plugs 4 a couple of thousand miles but out of the blue stopped firing.
I was actually getting ready to pull the carbs because it had been sitting for a bit and I thought some of the carbs weren't flowing fuel through the jets.
But when I spray gas into the individual carbs I realized it was ignition.
These were NGK iridium plugs. I put a set of standard NGK plugs in and it's been running fine ever since.
I'm sure it would be rare to have a problem on a newer automobile engine but I get years out of the cheaper ones.
762mm
Quebec, Canada
Thanks for sharing your experience. I agree that iridium are quite expensive all things considered, however I lucked out and RockAuto had the Champions for like $4-5 per plug. I could not say no to that, lol! (Champion is good quality and it is also the standard plug for all Dodge, from what I've read)
As for longevity, I don't plan on keeping them in there past 80,000 miles or so. But... I do value the peace of mind they offer, plus the fact that they might save me money on coils down the line. Since I have another truck to drive to work every day and the Expedition is my week-ends / days off truck, I expect those plugs to last a very long time for me.
The truck runs very smooth on them, by the way... I definitely saw an improvement over the old (worn out) ones, as could be expected.
TobyU
Ohio
You should be good to go for a long time.
I have always hated Champion plugs even though they are OEM for Chrysler products. I will say they're the best for lawn mowers though. Everybody out buying these first fire and E3 plugs for lawn mowers are just wasting money. You need nothing but a standard plain old Champion plug.
I might have put champions in a Chrysler or a Jeep with a 4.0 only two or three times in my life because the owner had bought those plugs or wanted Champions put back in. I would always opt for another plug if I had the choice but that was a few years back.
When the Ford 3 valve problem first showed up Champion was the best plug to install when you took out the factory ones because it was the only one piece plug design. Now that Motorcraft has gone to a one-piece design I would go with those on a 3 valve.
It's funny how certain people will have one experience with a product and then bash them for the next 20 to 30 years. I see a lot of people on a couple of different forums that don't like Autolite plugs. I have never had a problem with an Autolite plug ever. They were always my second plug for a GM cars. AC Delco first and then Autolite if they weren't available.
4 Fords my first choice would be Motorcraft what's second being autolite.
However, today, there is not that much difference in Brands. It's mostly about the plug composition as in standard top, Platinum, iridium.
I will caution you about Pine plugs online through Amazon or Ebay and maybe even RockAuto. Inspect the plugs very carefully because there have been several posts with pictorial evidence to show counterfeit plugs. I believe the counterfeits were with NGK but I might have seen something about Motorcraft also.
They had contacted NGK and gotten the numbers off the plug and not the standard part number. They were confirmed by the company to not have been made by NGK.
That gets pretty scary. I have no problem buying lower-quality no name or off-brand Chinese replicated, copied parts for a low price but I do not like the idea of counterfeit goods for car parts.
If I want a cheap ass junkie plug I'll buy a Torch . That's what comes in all the Loncin and Chinese snow blowers and mower engines now.
H
Hoos95
UPDATE:
Ordered (8) Motorcraft DG511 ignition coils to replace the aftermarket ones installed a few months ago. Will take the vehicle to the shop once those deliver and swap them out along with replacing the bad head gasket.
