Nothing like a Catalytic Converter burn
Scott Carden
Dallas Texas
I serviced my 2014 el king ranch about 11,000 miles ago. The crossover pipe is a pain in the butt and the converter is hot! But despite the pains it’s a really good transmission and requires very little service. As I understand it, it’s one of the only transmissions that holds a pressure and if properly serviced with Ford filter and fluids it can last as long as the engine. Also worth note is that from all the info I have seen, if you do have to rebuild it, no special tools are needed and the most important thing is cleaning the parts exceptionally well. I wore a cheap long gauntlet glove from amazon to keep from getting burnt by the cat and used a cheap hand fluid transfer pump to fill the tranny back up. So there are a few minor quirks but I’ll put up with it for the durability that far exceeded anything I ever got out of GM or Dodge.
bobmbx
Us old-timers know a trick to keep from getting those nasty burns and knuckle busters....
"Call me when its done"
Rexpedition
So I posted this on another thread... but maybe it really belong here:
I'm getting ready to start poking at the trans on the 2012 Ex I just bought w/ 150k on the clock... I figure it's never been touched and is running well now - so some PM is in order...
My question is, can I avoid the hot level check if I'm careful?
I mean, if I get it hot, park in garage on 4 ramps, let it cool, check fluid level and mark/note it, drop/clean/reinstall pan and filter, fill to same spot - there is no need to worry... right?
O, hello from a newbie joining what looks like a very helpful forum :). I've already been 'broken in' by the T-connector.... And right after changing plugs/boots!!:mad:
Thanks,
-Tony
Trainmaster
Old School Member
Rockaway Beach, NY
If I check the level in my 2010 Explorer when cold, the fluid spills out. I'm not sure if the fluid from the cooler drains back into the pan giving a falsely high level when cold. That level may be over the top of the mini-dipstick hole.
Since that wonderful experience, I only check the dipstick-less Fords hot.
I assume your 2010 Exploder has the 4.6L if you have the 6R80 trans in it? I never realized how sexy the intake manifold is on the 4.6 3V Explorers until recently....it’s a nice layout in the engine bay. Kinda wish the 5.4 showed the intake off like that instead of the engine cover or ones with the huge intake w/ resonators.
4.6 Explorer
5.4 Expedition
Rexpedition
Thanks for the insight, Train. I didn't expect to hear that that! Are you sure this is the same for my 2012 Expedition?
Trainmaster
Old School Member
Rockaway Beach, NY
Unfortunately, I have no idea if this applies to the Expedition. Crack the nut on it cold and just be prepared for some fluid's escape and you'll find.
07navi
Mt.Shasta California
They have Expy trans oil gloves at Amazon for wimps but all you need is something to lay on the cat like a wet rag or something. Also some mechanics just check the trans when it is cooler and subtract 1/2" +- from the little dipstick to compensate for hot oil expansion.
