Ford, GM and Chrysler all tried turbo charging in the 80's. They all phased them out. Why? Now 25+ years, Ford, comes out with the Eco-boost...a turbo, again. Ford is one of the only car maker pushing it. Why? Turbos are spun by super heated engine exhaust at thousands of RPM. Air is compressed and forced into the engine. Compressing air causes it to heat and absorb moisture(damp weather issues). The air is forced through a intercooler, to lower the temp. The increased combustion pressure, causes spark detonation( high octane gas debate) and potential head gasket failure. Constantly overheated turbos can fail. The Obama, 55mpg C.A.F.E mandate(Trump ended), pushed automakers for more fuel efficiency. Maybe Ford worked all the bugs out of turbo charging. The same company that had, V8 spark plugs ejecting and plastic intake, catastrophic failure recall, just a few years ago.
There is so much wrong with your science and understanding of physics, chemistry, and the function of a turbo charged motor that there is no way I could put it in to words to fix your logic. I need a whiteboard!
Just a simple concept, the moistness of the intake charge does not change once it enters the intake. Since no moisture can be added to the system, heating the intake charge, will not cause it to "absorb" moisture.
Another simple concept. There is no such thing as Spark Detonation. There is Detonation, and there is Pre-Ignition. Detonation is AFTER the Normal burn from the Spark, and Pre-Ignition is BEFORE. Both are without the spark plug firing.
A LOT of companies are investing in Turbo Tech. Nissan has several new small turbo motors, vw has very few NA motors left in their vehicles, even GM has jumped on board, just haven't gotten to the bigger motors, other than the Duramax.
Stay in your cave, and ignore the Tech. With computers and variable valve Turbos, it is A LOT different than 24 years ago, in addition to better oils and metals. MANY improvements.
