Yep...got one guy on here, thinks the Eco is a Bad Motor...then there is everybody who actually drives one. We Love it.
People keep saying that the point of the Eco is better MPG. It does have better MPG, when Output is factored in, at the Same MPG as the 5.0 based on Fuelly, the Eco Boost gets 40 More LB/FT, and has more usable power, because of how flat and steady the powerband is.
We keep hearing the 5.0 is better in the long run because of maintenance, yet I have really not heard any horror stories with the 3.5 across the board. Hell even a V8 can have it's own set of issues. Let's take the 5.4 for example and it propensity to spit spark plugs...Only time will tell. So far the EcoBoost 3.5TT has a great reputation.
Turbos produce enormous amount of heat. Exhaust, direct, from the engine, spin them. Ford, GM and Chrysler sold turbo cars in the 80's. They all had good performance and turbo issues. They were phased out, why? Now Ford brings the turbo back, but call it the Eco Boost. It is the same technology. Drag racers, with turbos burn Methanol. It is easier on the turbo. Locomotives are massive, turbo diesels. They rarely get shut down. If they do, a electric oil pump, sends oil to the turbo, for 30 minutes.
Like Jeff said, lot's of FLAT UP WRONG info in this thread. If you read it on the internet, and don't actually know the science, don't repeat it.
"Better to remain silent and be thought a fool than to speak and to remove all doubt." That applies to the Forums also.
Bottom line... You can run 87. It will not hurt your 15+ Expy. You can save a little money at the Pump. If you want the best Performance, run 91+. If you don't have to pay for your own gas, definitely run 91+, why not???
