Oil Change Interval in Winter
LG_123
Toronto
Does anyone change their oil change interval in the Winter?
I normaly go 5,000-8,000 kms (not miles) between changes depending on whether I've been towing or not. In winter I don't tow and had thought the oil might last longer than normal because our car seldom even gets heated all the way up with all the short trips around town.
I've always used full-syntheci Mobil1 5W30 and we're around 90,000 kms total now. 2019 Max Platinum.
99WhiteC5Coupe
What does your oil-life percentage monitor show in cold weather with short trips?
I’ve always thought cold-weather, short-trip driving is very hard on engine oil, as the oil does not fully heat-up to burn off any contaminants and moisture?
LG_123
LG_123
Toronto
If I went by the oil life monitor in the car, I wouldn't be changing it until 20,000kms which I'm sure is unhealthy. So I never pay any attention to it.
But I just went to look and it is degrading faster than normal. It's currently recommending I change after 10,000 kms (I'm at nearly 5,000 now).
I'lll likely wait another couple months until the weather starts warming up to do it.
MattG
Toronto
Full Synthetic at 5,000 kilometers is probably wasting a good amount of oil, IMO.
Oil life monitor reads average life of the oil based upon driving conditions, not some form of instant analysis, from my understanding. I've never seen mine go past 12,000 kms before it shows its near due for a change.
I typically change out the oil on the Expedition and the 5.0 F150 around the 8k-10k kms mark. Each time the waste oil looks fairly decent, whatever that may mean.
I'd stick to your regular schedule and not overthink it.
blue_roster_cult
Missouri
I used to change the oil at 9k miles, using Schaeffer’s 9000. I got tired of paying for it and switched to Ford blend every 8k miles. I currently have 175k miles. I’m not sure why you would change for the winter months unless you’re running thinner weight.
Hellwig
your vehicle model year is?
LG_123
LG_123
Toronto
Thanks for the input
sjwhiteley
Kentucky
Just use common sense. Colder weather is harsher starts; change it ‘more often’. Since people are all over the place on when to change oil in these vehicles, it’s really up to you.
I use the oil life monitor as a gauge for oil ‘wear’ (whatever that means), but aim for 4 to 7k. If the oil life is dropping faster, than change it earlier, and visa versa. Absolute value doesn’t matter.
SyndicateZ
Mass
Just stick to 5000k mile oil change intervals year round and you are good if you plan on keeping your vehicle indefinitely. Many leasers like to go up to and even past 10k miles and damage the engine for the next owner.
haviland
MA
Sorry to be a little off-content on this thread, but I found it very interesting that Mobile 1 full synthetic 5–30 is being mentioned as the oil to use. I would be so happy to learn that that is the way to go.
For the past several Expeditions I have been using Mobile 1 fully synthetic 20–50 and it is very difficult to find.
Should I switch to the (much easier to find) 5–30?
Thank
Peter.s,
LG_123
LG_123
Toronto
5w30 is what's recommend in the manual and on the oil cap so I've never experimented with anything else. 20 weight sounds very heavy to be putting through this ecoboost engine.
GaryH
Army
Thank
Peter.s,
IMVHO...yes. 20w50 is too heavy of an oil for Expedition. What does the owners manual and the oil fill cap call for?
