Canyon Man
In regards to it not starting....cant I disconnect the sensor and then try to start it. Because then the computer wont send it into limp mode.??? Would this work?
If you need any electrical prints let me know I have a complete set for both the 1st and 2nd generations along with service manuals
OK....a little progress. I disconnected the sensor under the intake manifold and the truck started right up, a little rough but it started.
for the starting issue you may want to check fuse 2 and 18 under the hood
and fuse 2 and 30 under the dash.
you can also try spraying a small amount of starter fluid or carb cleaner into the intake to see if the engine fires but again just a small amount
