2003 5.4 2v
207k miles
P0175 code started yesterday.
Driveability unaffected, no stumbling or hesitation noticed. Coolant temp gauge appears to operate as expected, starting cool and warming up.
PCV Valve (motorcraft) replaced 2 months ago.
Long term fuel trim bank 1 -22.66%
Long term fuel trim bank 2 -25.78%
I cleaned the MAF sensor and looked for vacuum leaks, then reset the error code, but what's the next logical step if/when this returns?
From the shop manual:
P0172 - System Too Rich (Bank 1)
Description: The adaptive fuel strategy continuously monitors the fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. Refer to Section 1, Powertrain Control Software Fuel Trim for more information.
Possible Causes: Fuel System:
P0175 - System Too Rich (Bank 2)
Description: See the description for DTC P0172.
Possible Causes: See the possible causes for DTC P0172.
Diagnostic Aids: See the diagnostic aids for DTC P0172.
Data:
207k miles
- Fuel pressure regulator (vacuum hose off, diaphragm leak).
- Leaking fuel injectors.
- Fuel return line restricted.
- Fuel rail pressure sensor (incorrect reading).
- EVAP canister purge valve leak (when canister is full).
- Engine oil contamination.
- Mass air flow (MAF) sensor (contaminated, damaged, or corroded connector).
Data:
