Press Stop Underway, Automatically Shifts to Park???
mhExped
I read a post/complaint on the NHTSA website where the author explained how the '18 (and newer?) Expeditions (and all modern Fords?) automatically shut-down and shift to Park if the start-stop button is pressed while underway.
Wanting to know if this was true, I did a simple test in my driveway with my '18 Limited, taking my foot off the brake while engine running and car in drive (but essentially not moving due to vehicle's positioning in my drive). Pressed the start-stop button and sure enough the car immediately shifted to Park and powered down.
Like the author of that complaint on the NHTSA website, I'm concerned that should one accidently depress the start-stop button while driving at highway speeds, the results could be disastrous.
Anyone have more insight into this behavior? Hopefully no one has experienced this situation first-hand in any way that resulted in tragedy.
Going_Going_Gone
Phoenix
I can only speculate on when Ford introduced the Torqshift 5-speed transmissions in the 2003.5 Super Duties. Because the transmissions were all computer controlled, they said you could move the shift lever into Reverse when going 60 mph and nothing would happen as the computer would recognize that would not be a good move. If they had those protections 18 years ago, I would assume they would incorporate that feature on the ten-speeds as well (unless that was the part of the joint development that GM performed;))
KenK
Houston
I use this feature all the time when stopping and parking but no way I have the guts to try it while moving. In theory the transmission won't let you do anything stupid like shift into reverse while moving forward.
Deadman
Wisconsin
I WILL say that if you open the door on my 18 at any speed, the trans slams into park and tries to shear off the internal park pin. idiots!
flying68
Wichita, KS
Hit the stop button as I was slowly rolling to a stop at the mailbox and it stopped abruptly. I was only going a couple mph with the foot off the brake. Seems like there needs to be a software update to prevent the transmission from going into park unless the brake pedal is pressed and the vehicle wheel speed is 0.
lobsenza
I found this out when backing a trailer down the boat ramp. Mine slammed into park when I opened the door to see if I was deep enough. Stupid design. I now compensate and do not do this. Supposedly, if your seat belt is buckled, it will not slam into park. I always wear my seat belt, except when backing a trailer because I find it gets in the way.
Uturn
Are you sure it actually slammed into park? The transmission is supposed to shift to neutral until the vehicle stops, then shift to park. The indicator will show park immediately. The slam into park is probably the parking brake applying which is what is supposed to happen if you shift into park with the vehicle moving and the brake not firmly applied. From the owners manual.
On a console shifter, when the ignition is
turned off, your vehicle automatically shifts
into park (P). If the ignition is turned off
when the vehicle is moving, it first shifts
into neutral (N) until it comes to a
complete stop. Your vehicle then shifts
into park (P) automatically.
The electric parking brake may apply when
you shift to park (P) without the brake
pedal fully pressed.
aggiegrad05
North Texas
And just to reassure everyone your vehicle is not trying to kill you, if you open the door while moving AND YOUR SEATBELT IS ON, it will stay in D.
I just tried it.
AAOO
@Deadman As long as the seatbelt indicator is not lit up on the dash you can open the door while underway and it will not slam into park. You can buckle then unbuckle your seatbelt and it won’t slam into park or keep it buckled behind your body when needed.
