Really?, you should stop giving people suggestions. I guess they are supposed to be loose so they unthread and fall offNope they arent supposed to be torqued tight anyway
So did you get the spacers in?Sway link was loose. That's it.
Phew!!
Nope. Maybe next weekend.So did you get the spacers in?
unfortunately no, they come pressed in as wellNope. Maybe next weekend.
I'm glad you know what I was talking about with the bolts on the shocks. Very frustrating. Do the aftermarket shocks have those bolts seperate?
That sucks.unfortunately no, they come pressed in as well
got a piece of wood and drilled out a hole a little bit larger than the top of the shock. set the top of the shock into the hole and held on tight while my dad hammered them out. several heavy blows from the hammer knocked them loose. and I mean heavy blows. make sure you thread the nuts on backwards to cover the tip of the bolt which gives you a better surface area to strike. 10 minutes to take out all 4That sucks.
Ok. So what was your method for hammering them out?
If I get new shocks, I think I'll go with oem, but upgrade the rear to self leveling shocks. I'll have to look at pricing since I'd have to replace the rear coils.
My '14 is lower to the ground than either of my previous first generations. I got used to being higher up and I want my 3rd generation to match it. Right now the running boards are pretty much useless for me.OK ... I have to ask this question. I bet it sounds pretty dumb but I dont know. WHY do people "lift" their Expy's? Is it to get more ground clearance for off road? Is it because they want to run bigger diameter tires? Is it because they find that it makes the truck look better?
Bigger tires and looks for me. Only “off roading” I’ll ever do with it is the beach in OBXOK ... I have to ask this question. I bet it sounds pretty dumb but I dont know. WHY do people "lift" their Expy's? Is it to get more ground clearance for off road? Is it because they want to run bigger diameter tires? Is it because they find that it makes the truck look better?
I'm pretty sure my 97&01 was completely level. I can really feel the rake on my '14.Fronts often also lifted a bit because of the "factory rake" (truck leans forward/downward an inch or two up front)
Calipers and rotors for a spacer? Must’ve been here first one. Thts sad
It's the bolts on the bottom of the struts that was the problem. The rears went in a lot faster.Calipers and rotors for a spacer? Must’ve been here first one. Thts sad
