Raising a 2014 Expedition
oldpaddy
oldpaddy
Cape Cod
OK ... I have to ask this question. I bet it sounds pretty dumb but I dont know. WHY do people "lift" their Expy's? Is it to get more ground clearance for off road? Is it because they want to run bigger diameter tires? Is it because they find that it makes the truck look better?
My '14 is lower to the ground than either of my previous first generations. I got used to being higher up and I want my 3rd generation to match it. Right now the running boards are pretty much useless for me.
J Ski
3.5plati
VA
Bigger tires and looks for me. Only “off roading” I’ll ever do with it is the beach in OBX
Adieu
SoCal
Fronts often also lifted a bit because of the "factory rake" (truck leans forward/downward an inch or two up front)
oldpaddy
oldpaddy
Cape Cod
I'm pretty sure my 97&01 was completely level. I can really feel the rake on my '14.
sjwelds
Kansas
Thought about lifting mine a bit, but really just not a fan of how the rear wheels swing forward when these rigs are lifted. Not knocking those of you with a lift, just personal opinion.
Plus, for whatever reason, mine sits pretty much level. Guessing the rear springs are beat down a bit after 150k+ miles.
oldpaddy
oldpaddy
Cape Cod
Got her raised!
Felt at home once I got behind the wheel. Much better.
They didn't have to take the bolts off the shocks, but they did have to remove the front calipers and rotors. At one point there was three guys doing one wheel. The front took them a while.
J Ski
3.5plati
VA
Got her raised!
Calipers and rotors for a spacer? Must’ve been here first one. Thts sad
othermrsikes
