Readylift 3/2 and towing
Gillbrak
Denver
Any first hand experiences towing a travel trailer or anything of weight with the 3/2 lift kit? Our TT is about 7500 lbs. can you run this lift along with the Hellwig sway bars?
Fozzy
Riverton
You will be fine. Just stick to safe towing practices. WDH properly set up. Tire pressures and load ratings met. I feel the Expy has weak brakes and the oversized tires make it worse so make sure you have good trailer brakes and controller. I have the 3/2, 35” tires,Sumo’s and the Hellwig rear bar. It’s a towing beast.
DavidD
Las vegas
I’ve got the 3/2 with 34” tires on my 2020 limited and towing 5-6 thousand pound 16’ trailer no issues as far as getting power or stopping I’ve got brakes on on axle. Tows great, slightly higher rpm up hills but nothing to crazy. Tows like a dream!
