Alwaysthinkin
@Alwaysthinkin I did the same as tunage, during install I used a silicone based lube (for brake parts rubber boots) never had a squeak to date (installed in mid March 2021). I cut off 1/2" of the center sleeve. 2 wks ago while installing bilstein struts I cleaned & re-lubed them. No noise from them at all.
Thanks @5280tunage and @DWs-TTEB for both your responses. Not sure when I'll get the bar installed but I should be all set (also got ramps). Then I'll recheck the rear bar to make sure it is correctly torqued. Must admit, I'm kind of excited to take it for a spin when all done!
