bmrisko
I decided I would replace my pass. side exhaust manifold in holes of fixing an exhaust leak that has been prevalent for a while. The first 7 nuts came off easy, so I was feeling pretty good until I got to the 8th nut (bottom, closest to the firewall). It was backing off way too easily and then fell off with the stud broken below the surface.
It is not one that can easily be drilled out, but I figure I can try building it up with my welder and then welding a nut on it to back it out. However, my other issue is the gasket mating surface on the head around this stud hole appears to be eaten away some. Any idea what would have caused this? Not sure if I get the stud out and replace the gasket and manifold that I am going to due much good due to the area around the stud that appears to be worn away.
