Theres 3 different sway bar options for rears.
Depends on your suspension
Have any part numbers?
I am looking for an update on this thread. I have a 2014 Expy EL Limited w/hd towing pkg. and am contemplating going to the Hellwig sway bar if it will significantly improve vehicle handling while towing. I tow a 29ft., 8,000 # trailer with reese wdh and cam anti-sway.
Thanks for replies from experience.
Sounds unlikely.
Its just a piece of metal that shifts in bushes and flexes a bit, forming a loose connection between the opposing wheels
Sway bar bushings and links would be more important.
And all that is pretty secondary compared to the coilovers.
I would actually disagree. I have upgraded Sway Bars on previous trucks and they made a HUGE difference on rear sway when towing at or close to vehicle limits.
Did you upgrade the bar separately from the links and bushes, or all together?
Just the bar in some cases, and all together in some cases. Both made a difference.
The stiffer bar is where the most difference was made.
This sizing problem still exists for the Hellwig rear sway bar for the 2018 Expedition. Thought an update would be good. I wish I saw this thread earlier. I only found it because I was trying to understand why the sway bar seemed too short. I’ve installed a rear sway bar on a Toyota truck without any issues, so I don’t think it’s me. I’m going to force it on tomorrow and take a pic to upload here as well as to send to Hellwig.See how it's a bit narrower? Hellwig on top, stock on bottom.
Attempted install anyway and the bushing can't close completely.
I would like to add the Hellwig's to my 2018. Any update on availability?
