Shift Flare on 1-2 shift?
Discussion in '3rd Gen - 2007 - 2017' started by Beckta10, Jun 27, 2019.
  1. Beckta10
    Beckta10 Active Member
    29
    38
    Dec 9, 2018
    Illinois
    Correct. But this was the middle of summer 75-80 degrees and it was a huge cloud of smoke multiple times. Hasn’t happened since. I live in IL and turbo was replaced in January (smoke first noticed the prior August) so I’ve seen the full range of weather since.
  2. Munkiebunz3
    Munkiebunz3 Full Access Members
    36
    211
    64
    Sep 20, 2018
    Soviet Monica, Kommiefornia
    I'm getting that smoke upon startup also with 70+ temps.
  3. 16plati
    16plati Full Access Members
    29
    1,105
    333
    Mar 22, 2019
    VA
    White smoke means that u blew ur Head gasket! The car overheated sometime....maybe ur thermostat (simple item) to a water pump (more complicated)....and that pressure blew the head gasket allowing the antifreeze and oil to mix....and coming out white.
  4. 16plati
    29
    1,105
    333
    Mar 22, 2019
    VA
    Coolant leaking in somewhere sounds like. Maybe a blown head gasket??
  5. bobmbx
    bobmbx Full Access Members
    57
    964
    462
    Jun 11, 2017
    Is it smoke or steam?
    The EBs will "steam" a bit at startup. Mine does it, most commonly at first start of the day. As an old school guy, when I first noticed it I too thought it was a headgasket, but it isn't. Its just a normal condition for these engines.
  6. 16plati
    29
    1,105
    333
    Mar 22, 2019
    VA
    Sounds like they describe smoke which is gonna be coolant leaking or oil or both since the turbos are oil and coolant cooled
Share This Page
