Sound and vibration ... please help
Alaa
Saudi Arabia
Sound and vibration when the direction of the right or left, note that the car-4 wheel drive
JUST4FUN
Admin
Moderator Administrator
Il
is it in 4 wheel drive when this is happening?
mindgame
Honolulu, Hawaii
probably the IWE solenoid needs replacing... Can you lift the vehicle so all four wheels are off the ground? If so, does all 4 wheels spin while in 2WD mode? If so.. You got a vacuum leak that is allowing the hub actuators to engage..
hubs are disengaged when vacuum is present..
hubs are engauged when no vacuum is present.
