Steering is heavy all of the sudden?
Middle Ga
Have you checked the fluid level yet?
The level on mine can be seen without removing anything. It is a ****** reservoir on the drivers side closer to the engine on mine. If the fluid is there I would suspect the pump.
I have rarely seen power steering go quietly without it being the pump. Hopefully some of the mechanics on here can join in.
I imagine this thing is a beast to steer without PS.
NC-Expy
NC-Expy
Apex, NC
just checked the level of the PS fluid, it's a little bit above maximum but it's quite black.
dirty in other words..
should i drain it and refill?
NC-Expy
NC-Expy
Apex, NC
also...
where can i buy PS fluid...
never really replaced it before, i know i need to use Ford premium or whatever but please tell me i don't have to buy it from ford...
nvycrmn
Springville, IA
you can go to any autozone or somewhere like that and pick up PS fluid. if it is black, i would def get it changed out. it could just be clogging your ps pump.
NC-Expy
NC-Expy
Apex, NC
thanks. think wal-mart would have any? i usually get my engine oil from there
joezek
psl, FL
Any updates? Is it fixed?
Did you check the belt to see if it slips?
Isn't there a wire and a sensor mounted on the pump to monitor or control pressure at various speeds?
NC-Expy
NC-Expy
Apex, NC
sorry for the late response, but yeah, all i did was get it inspected, told them about it.. they said everything is fine. after a couple of days it just turned back to normal... air pressure in tires didnt change.
jacks3am
michigan
i hate my steering, its so easy to steer that i could a pinkey, i dont like it like that, i love it staying in place, with a little resistance while turning
ELVATO
Orlando, FL
Install some underdrive pullies. It'll free up some HP, and underdrive the power steering, which in turn will toughen it up a little.
jmdunham2
