Stripped intake manifold bolt
splintrcel
Milwaukee
I had dumped coolant on my engine and caused two cylinders to misfire. I pulled one coil pack out with ease but the second coil pack bolt had seized up caused the thread insert in the manifold to strip out. Anyone else have this issue and have an easy solution. I was thinking of cutting the bolt head out and getting the thread insert out of the manifold and making a new one. I really don't want to get a new manifold over one screw.
semperfi96
Huntsville
I have the same issue, but I run it that way, Took a paint stick broke 2 parts off stacked on top of each other then bolted my fuel rail down to hold the coil in place. Made sure the injectors didnt leak and so far so good. Redneck fix indeed
05expedeb
Medford NJ
A little late now but when you reistall the bolts put some anti seize on the threads.
Dmcritt22
