Stuck at gas station truck won’t start
Got it into neutral a few of us rolled it into a spot. The red anti theft light is staying illuminated when I turn the key.
Going to try disconnecting battery for a bit but I think ultimately she’s going to be put on a flatbed and sent off to the dealer. Also going to hit the starter with a hammer for sh*ts and giggles.
Spare key is also being treated like it doesn’t belong to the truck
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Loki I owe you one! I left it unplugged for a while and she started up! Thank you thank you!
No Problem!
Yeah, It’s a damn Computer with a Motor Attached.
The Keep Alive Memory was most likely corrupted in some way. By you disconnecting the battery and draining all residual power, it gets completely cleared. Apply power back and it has to reload from scratch.
If you start having to do that more often than every once in a while, you have a ECM or BCM going bad.
Plati
That's a cool trick. Was it the headlights you turn to ON?
Is that the same effect as this?
Kinda funny. I was driving in pouring rain today and wanted to make sure my lights were on ... Didn't actually know which position that was. Had to Try it later to learn
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Similar.
I do not recommend that method. If done incorrectly, it can actually Damage sensitive electronics. Removing the battery cables completely and opening a manual circuit like a headlight switch, causes an open circuit and creates enough draw to drain the capacitors and wipe the KAM.
Also, I don’t carry a wire around in my truck. The method I laid out can be done by anybody, on most places with very simple tools.
bobmbx
Similar.
IIRC, pulling the battery cables resets the powertrain and clears the fault codes, but does not reset the drivetrain (transmission). Shorting, described in the video, will reset everything. I don't have empirical data on that, though.
