Theft light blinking
dewey630
hankinson
ok...started out as a heater core replacement. I took me a few days of on and off working to finally replace the heater core, and all this time the battery was disconnected. I did not completely remove the dash, just got it loose enough to remove the cowling on the heater core. Yesterday, finally got it all back together. Went to start, and the theft light was blinking fast. I looked up on the net. Tried the procedure of cycling on and off 3 times. But it didnt work. I disconnected the battey for an hour or so and retried. But again, nothing. Any ideas? Thanks
Bedrck47
Elizebethtown, PA
When you want to clear the cpu, you need to do it completely. Take a look at this procedure.
https://www.youtube.com/watch?v=hZAsoqmqhdM
Although this may be a very good video and advice it really has nothing to do with the OP's problem. If the Op missed a connection it wouldn't do any good to try and reset the cpu as the missing connection would still give a theft light flashing
His problem is that he disconnected wiring to repair the heater core and since he reassembled He is getting a theft light blinking.
I would agree with stamp1127 that the problem is that the Op missed a connection
D
dewey630
hankinson
Ok....tried something today. Rechecked connections on lower passenger side....ok. tilted the steering wheel a couple times kinda hard and light went out. Truck started right up. Turned off and on....light blinked a couple time, then off. Again started right up. Loose connection? I just dropped steering down but not removed. I didnt even detach the dash from that side.
Temple, Georgia
Check the connections near the steering column. It may be the pats transceiver that is causing the issue. It may have pulled loose when swinging the dash or dropping the column.
D
dewey630
hankinson
Ok, took dash apart and check connections....everything was good. pulled cowling from under steering and a clip by the ignition switch was hanging there....its a single black wire with purple tracer. It slides into a slot in the switch but the black wire is bent....is this a problem? I enclosed a picture of it.
Temple, Georgia
What year is your expy? For my 99 it is the warning chime lead for key in ignition.
D
dewey630
hankinson
would it have anything to do with the instument panel? I did remove that looking for dash screws?
D
dewey630
hankinson
ok....just rechecked everything. i do see a grey 6 pin connector with 5 wires to the left of where diagnostic tool plugs in to, thats not connected to anything. i dont see any pigtail hanging anywhere. would radio have anything to do with it? Also noticed battery charge is down....got charge on it right now
Was charged overnight....but no change
D
dewey630
hankinson
oh boy....i feel like a fool. Started tracing wires, and guess what? The 4 wire from key runs down along column, i ended pinching it when i bolted up the support. I unplugged the connector and removed and verified wires were ok.....reassembled and volia, life. Thanks for all the help.
