Cutty
Hi all, new member in southeast Tennessee. I have an 06 with 173k on it and it runs very well.
Recently started hearing a ticking or tapping noise under the hood (i thought). Had a similar noise before that I tracked to a loose plug on #6 cylinder. Found it easily with my stethoscope.
Took me a little longer to track this one down but it is definitely coming from bell housing. Pulled inspection cover and noise was louder. Rotated flex plate around and checked all nuts and didn't find any loose or obvious damage to flex plate.
Trans shop wants 600 to 800 in labor to pull it out (4wd).
Today i noticed a slight noise from starter as it engaged or maybe disengaged from flex plate. Anybody have any experience with this? Not knocking loudly or anything and I dont hear it while driving but i dont hear well either! The noise is there in any gear and the trans seems fine. No noise from motor or trans under there, just from bell housing. Thank you in advance for any suggestions.
Sent from my SM-J320V using Tapatalk
