whtbronco
I've heard light chattering from the timing chains at startup for a while on my 2004 5.4L 2V, 299k miles. 42 days ago I started it and immediately it revved to 2300-2400rpm. By the time I looked at the tach it stopped increasing and dropped back to 1200-1300 like normal at cold startup and then slowly settled down until it reached 800 as normal, but with a slight increase in vibration. It's still running okay more or less. The dozen or so subsequent starts have been uneventful. However, it doesn't sound quite right in neutral on quick rev to say 3500rpm. WOT acceleration, in gear of course, feels normal. It sounds a bit deeper, like the timing is off a bit. Maybe the idea that the timing is off at higher throttle application is just my imagination since I know the timing set is nearly worn out.
I'm not so sure the high rpm at startup anomaly is actually related to the timing. I checked for codes, nothing engine related. Just the expected codes for VDM calibration and the drivers side mirror position sensors. I checked the TPS data stream and it seemed to be reading fine. I'm wondering if maybe the IAC valve was stuck for a second for some reason. Any thoughts.
Back to the timing chain stuff.
I like the idea of pulling the followers(rocker arms), but I have trouble grabbing anything in a pinching motion so I'll use the Ford method instead. I'll hold the crank and cams with one of the available 2V timing tool kits.
I'm still toiling with standard or high volume oil pump. Water pump has just 10k miles on it, so I'll leave that for now.
I'm likely gonna use the Melling timing kit and buy the one with cam sprockets since I can't figure out how to identify if mine are replaceable or not until the front cover is removed. I tried to find the difference between Melling service grade and professional grade, but I couldn't really find anything. I have used Ford's service grade parts many times with good results. Due to the lack of info I'll go with prof. grade.
It appears that removing the cooling hoses is the consensus here to help with getting the passenger side valve cover off. Much to my amazement the factory coolant hoses are still intact, except the hoses at the rear for the rear heater core. Now is a good time to replace them all though, 20yrs is long enough considering I'd only expect 5yrs.
Any thoughts on a harmonic damper installer that works without removing the radiator? I need a new one. I hate to spend $110 on one from Freedom Racing since I won't use it many times, but it should work. I am not tapping it on with frickin hammer again and the local parts store rentals didn't work.
Wow the this is complicated and costly compared to an OHV engine.
