Tips for remove/repaint/reinstall 1999 EB 4x4 trailer hitch? Can I reuse the hitch-to-frame bolts? Other forums says bolts are single-use.
Saxxist
California
S
Saxxist
California
My concern is from a Safety Recall 00S05 done on the vehicle in 2000. The bulletin says they would reinstall the hitch assembly "using updated attaching hardware at a higher torque". What is that higher torque, and can the bolts be reused?
Billme
Hattiesburg,Ms
They are just putting a stronger bolt on.. Everything is the roll of the dice.. Are all the bolts going to fail at the same time? I doubt it.. I would torque them down to spec and replace as one fails if you don’t want the upgrade..Check on them every now and then..
Hamfisted
Ft Lauderdale
You can call the dealer service department and give 'em your VIN number and ask about the safety recall for the hitch bolts. Maybe they'll have some in stock. They bumped the torque specs up on them too.
Recall 00V073000: Trailer Hitch Attaching Bolts Loose​
Vehicle Description:
Multi-purpose vehicles. The trailer hitch assembly to the frame attaching bolts could lose the clamp load. The trailer hitch could then separate from the vehicle. Dealers will replace the trailer hitch mounting bolts and nut plates. Owner notification began May 15, 2000. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact Ford at 1-800-392-3673. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236).
1997 FORD TRUCK EXPEDITION
1997 LINCOLN TRUCK NAVIGATOR
1998 FORD TRUCK EXPEDITION
1998 LINCOLN TRUCK NAVIGATOR
1999 FORD TRUCK EXPEDITION
1999 LINCOLN TRUCK NAVIGATOR
2000 FORD TRUCK EXPEDITION
2000 LINCOLN TRUCK NAVIGATOR
