Tips for running RCA cables from HU to back??
philly single
NJ
Hey Guys -
I'm putting in a pretty basic system in my 2001 Navigator. I have the sub taken care of, all the door speakers in and new wires run...but the part that is driving me NUTS is trying to figure out how to run the RCA cables from the HU through the dash and to the amp in back.
I can get a metal wire from behind the HU and out the bottom to the driver side, but can feed the actual cables.
Any tips? Do I need to really rip the dash apart to run these cables?
Thanks,
Jay
sgtowing
Supporting Members
Valrico, Fl
I'm afraid so. It's not usually to bad. There are probably videos on youtube that show you how to do it.
oblivion
Ontario Canada
2 suggestions. 1 when you fish the wire through hook the RCAs near the middle of the cable, bend back the wire 3-4 " an tape where they meet and slowly pull through. 2 pull the RCAs from the top down withy he same method. A lot of times you can hook going up through the dash but it I super clear going down.
Newport News, VA
I ran mine backwards...meaning I hooked it up to the amp then ran it to head unit...one key thing is to run it opposite of the power wire so u dont get interference noise...I ran mine under the carpet and out of the carpet on driver's foot area then up in the dash to head unit...dont know bout ur truck or year but my carpet came up pretty easily for me to run it under...again...keep all speaker and rca's away from power wires
Newport News, VA
If needed u can buy extensions for the rca too...I think I have a 20ft rca cord for both my amps
oblivion
Ontario Canada
Generally this is true and ALWAYS a good practice. There are some exceptions. When in doubt pay for a QUALITY set of shielded RCAs. This is the most common place for induced noise into a system.
P
philly single
NJ
Thanks guys. Yeah, I've always been clear on the power one side / RCA's other side.
Guess this weekend, I'll try again. I tried going from the top down (HU out and down through the dash) with no luck. I know there's an opening there - I can get a metal hanger through there...just not the cables yet.
If no go, then guess I'll have to start taking apart the dash.
BIGRED03
Fla
How did the sound reduction material work? I happen to have a roll of it left and thought about covering at least the 3rd row back in not the whole floor.
oblivion
Ontario Canada
Without getting too offtopic, the sound deadening i have completed works GREAT. 3 layers on all doors including the rear gate (1 on outter skin 2 on inner) as well as the floor of the rear. Plan is to do the rest of the floor as well as the roof.
Philly single, you do not have to take the dash apart to run the RCAs. It is easier drivers side, take the radio surround off and radio out and put a light in the drivers foot well. You will see a few places that light can be seen through. Run the wire down from the top of the dash then hook the RCAs and tape the hook either in the foot well or the top of the dash and pull the wire AND push the RCA. If is snags a bit pull back turn/angle slightly and go again. it will go through. I got 3 of these through and they are NOT small.
P
philly single
NJ
Hey man -
I cannot thank you enough for the tips! After spending, literally hours on my own. I followed your tips and ran 3pr of cables from the new HU to the amp in probably 30m.
I owe you some beers.
Jay
