The Wrangler DURA TRAC quoted is an E rated tire.
(LT in the model name)
LT275/65R18
123/120Q E BSW 32.1" 11" 7.5-9" 8" 18/32" E - 10 ply 3415 lbs 80 psi 99 mph 50 lbs Black 648
I'm not a tire expert but I did my homework for my 2 sets of E rated Light Truck tires. The 35 psi recommendation is for Passenger tires. LT tires "need / can use" higher pressure. There are tables to guide you in choosing what pressure to use, or you can do the chalk test, or various other methods. You don't want to go up to 80 psi unless carrying a heavy load of weight in the vehicle. I think that's most of the idea with LT tires, you can carry a much heavier weight -- the tire can handle that - but you need to crank the psi up to compensate for the weight -- the tire can handle that. Under normal weight you still want higher than 35 psi. I run about 46 psi in my Falken Wildpeak and Kumho Road Venture LT tires. That results in an appropriate tire shape and "footprint" on the road with good tire wear and gas mileage.
Do I have this right? I'm not always right, I know that and I'm always trying to learn.
MrLoki … if its an E rated LT tire do you still think 35 psi is correct?
Pretty much all you said is correct
LT275/65R18
I think you covered about everything. An E Rated Tire can be aired up all the way to 80 psi if you need to or wish to Halt its maximum load but it should never be aired above 80 when cold.
No tire should ever be inflated over the maximum cold inflation printed on the sidewall.
Most vehicles with load range D or E tires do not need to be at the maximum inflation pressure. Most will ride firmer or uncomfortable at these higher pressures. However, I have seen some vehicles that actually ride smoother at at when they do at 62.
There also is consideration like you mentioned about even tire wear. I am more concerned about even tire wear than I am about ride comfort.
Paying close attention to your tires or the chalk method is the best method to determine what the best pressure is for even wear.
Also as you mentioned a load range E Tire should not be at 32 lb or 35 lb because the manufacturer printed that pressure on the door placard. Any number given by the manufacturer and printed on any official literature from them will also state the exact tire size and load range the vehicle was shipped with and that number only applies to that exact tire specification.
Even if a vehicle has a standard load Tire which most Passenger cars do oh, most of those tires either have a maximum flexion pressure of 35 PSI or 44 psi. The manufacturer usually has a low recommended inflation than that and it's typically based on comfort. The tires cannot support their full maximum load printed on the sidewall at those pressures. Most people will never load their vehicle even close to those pressures so it's a moot point.
When you switch from a standard load to D or E load range Rated Tire you should always increase the pressure higher than what the manufacturer recommended for standard load tires.
These tires are made differently and often even look quite low with only 35 PSI.
Most people don't need to be at the maximum but people be much better serviced to start out with at least around 50 in a load range E Tire even on a light vehicle carrying no heavy loads and adjust them there. The lowest I have ever run in a load range E has been 60. I typically like to run right around 72 unless it's on a vehicle that typically haul a lot of weight and then I go up to the 80.
Even on standard load tires I go much closer to the maximum inflation printed on the side wall and consider that number much more important than whatever the manufacturer stated to fill them to.
Just because Ford says to fill your tire to 32 or 35 PSI does not mean it is the best pressure or even the safest pressure. It might be printed in the book or printed on the placard but that does not mean it is correct.
