Towing Question
XLTExpoGuy2010
Houston, Tx
Just bought an 2010 Expo XLT, I was curious on how do I can find out the towing capacity for my truck? When I looked at the truck online on the dealers website under all features, it said it could pull up to 9,200lbs. With it stating that I just want to double check it, also if it isn't capable of that weight how would I go about upgrading it to an HD.
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Very true, didn't think of that. Lol let's say it didn't come with one what's my next option?
Bedrck47
Elizebethtown, PA
if you don't have the owners manual go to owner.ford.com and you can download the manual and any other manuals that would have been in the expy when new
also go to ford etis and enter your vin number and you will find information on what was on the expy when built
from the owners manual your max trailer weight would be 9000 lbs for 4X4 or 9200 lbs for 4X2
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Its a 4x2 so according to the brouchre I downloaded regardless of gear ratio I have the capability of pulling the 9,200lbs. Now another question it doesn't have a brake controller or anything so is that something I should add on? Or what are some things I should upgrade to it?
Bedrck47
Elizebethtown, PA
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Okay I'll check it out today. If I have a 4 pin do I need to upgrade to the 7 pin? I read on another thread about a guy trying to convert it.
Bedrck47
Elizebethtown, PA
if you have a 4 pin connector you most likely have the light duty tow package.
Yes it can be up graded to 7 pin
again check on ford etis and you will see what was on the expy as built
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Okay thanks Roxy! But with a light duty I wouldn't be capable of that 9,200 correct?
It's going to used to pull a camper the size hasn't been fully determined, though I would say it'll probably be between 22-28ft. I do have some decent towing experience I help my father in law with a 5th wheel. So I have the concept of pulling down, just know I do have to get stability bars for the expo.
Bedrck47
Elizebethtown, PA
for a travel trailer I would recommend a good weight distribution hitch and sway control. You definitely will need a heavy duty tow package you may also want to increase the size of the transmission cooler if one is already installed or install one if there isn't a cooler on the expy.
my best advice would be to talk to a good RV dealer and see what they recommend
also check with your Ford dealer to see what it would cost to up-grade to the heavy duty package if needed but be cautious on what they tell you about towing weights
again check to see what hitch and connector are already on the expy and post that information on the forum
also update your signature as that will help for future information and responses
it can be updated in the USER CP section
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Okay good to know. Well once I have the Vin I'll run it and check back here with my findings. I want it to absolutely be safest possible as I will mainly be the one pulling but my wife will maybe have to drive sometimes too.
Okay thanks for all the advice it has been so greatly appreciated!
I do have a signature set but its not showing for some reason.
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
So I just looked on the website format my signature works fine, but on here it doesn't show that's odd.
Bedrck47
Elizebethtown, PA
you have the 2010 showing but not the 2007
also will say it was a pleasure dealing with someone your age that has some common sense and gets the point across
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
I'm completely sorry Roxy, its supposed to say 10 not 07 I'm very sorry.
It has been a pleasure dealing with you as well, you have answered every question I have asked. Thank you for the compliment I appreciate it. I just have learned it helps to be as descriptive as possible it helps get a more accurate answer.
I will say this coming to common sense in the aspect of pulling a trailer. It's better to take your time and get there in 1 piece rather than rush it and hurt your vehicle and endanger your life.
DF5.4
Hilton, NY
On my 07 with the HD tow package it's rated at 9000lbs for my 4x4. 9200 for the 4x2. Without the HD tow package it is 6000 lbs for both 4x4 and 4x2.
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Oh okay. Well after looking at the brochure for the 10 Expo with the 3.31 & 3.73 gears for the 4x2 it shows the max load capacity is 9,200 but again I won't know more details until I search the Vin and find out the exact info for my expo.
Bedrck47
Elizebethtown, PA
"its supposed to say 10 not 07"
OK that clears up the confusion as your original post says 07 other that the tow weights which most likely apply to the 2010 all comments remain the same
XLTExpoGuy2010
XLTExpoGuy2010
Houston, Tx
Yeah it didn't snap, I'm sorry.
Well I'll grab the VIN in a bit and report what my findings. Great thing is, is we probably aren't getting a trailer till beginning of next year so I have time to save and do the upgrades you mentioned above.
