TPMS Annoyance
Daverulz
Madison, CT
Why on earth in a vehicle like the Expedition (2016) did Ford think it was OK not to include information on individual tire pressures? Even MORE annoying is getting into a rental Fusion and seeing this:
View media item 7040
I searched, but couldn't find definitive information on adding this display through Forscan or other means. Any insight?
Thanks!
Langer
Chicago
Thanks!
Everything I’ve read through in forscan thread shows it as a no go in the vehicle’s display. The information is there, you can access it with the numerous apps available like forscan, torque, etc., just not on the vehicle’s display. Very annoying. This truck is definitely the red headed step child in the family.
D
Daverulz
Madison, CT
it's just. so. stupid. Of all the vehicles that you would want to know exact tire pressures you'd think an SUV with over 9000lbs towing capacity would be one.
99WhiteC5Coupe
I ordered and bought a new 2015 Ford Expedition Limited 4x4. The salesperson told me that the individual tire pressures could be display - he was wrong or lied.
The lack of this feature, and several others, will prevent me from buying another new Ford.
PS - Wait until you open the rear hatch and your cargo falls out. Ford engineers couldn’t figure out how to provide a cargo net, or the provisions for one.
Langer
Chicago
Car salesman FTW. I always grab the first few items through the window hatch, already had a few misfires coming out the entire tailgate. Thankfully only lost a Bud Light or two.
07navi
Mt.Shasta California
I bought a cheap used laptop just so I could use Forescan to turn the dam yellow tire icon and the constant text off the info box and now the sellers tell me that Forescan won't work with a 2007 Navigator.
ExplorerTom
Colorado
Very true.
And also, before TPMS, no one ever towed heavy loads. Ever.
TPMS alerts you when the tires are 7-8 psi below set point which is before any performance or visual difference takes effect. Not sure what individual read outs offer other than to be able to say “oh I can see the exact pressure”....if you have to re-inflate the tire the compressor will tell you the exact pressure.
07navi
Tpms is for lazy people that never check their tires until they are half flat and us responsible people have to put up with it. Those batteries can go dead in as little as 5 years and then you are starring at a bright yellow tire icon on your dash or shell out a bunch of money for new ones, matching to your computer, and breaking the tires down after removing the wheels. Plus you can't have winter wheels unless you go through the same procedure...…...pain in the butt.
jeff kushner
North of Annapolis
I agree.....it doesn't make sense other than at least we get some warning if a problem is rapidly developing.
I had a pass side front tire lose 20lbs. I don't know how it happened, it just did. The warning came on....and of course it was the very last tire I checked.....but I pumped it up and it's been fine. Might have been some of that extreme cornering I occasionally do? Dunno but I was glad for the little warning. It might not have been so successful of a drift had I tried it on that low tire?
I do not understand the lack of position indication though unless a subsystem like one of the control modules couldn't handle the extra command requiring a change...then I can see why they didn't.
jeff
