99WhiteC5Coupe
I just put some TPMS's in a plastic tube, pressurized it, programed them, bungee corded them under the truck, and all done.
Why would you do this?
To get rid of the lights and text.Why would you do this?
This would work except the problem is not the TPMS sensors. He said "I believe there is an issue with the actual module that reads the sensors". Would be a good test though, but not a good "fix" as it defeats a safety alert.To get rid of the lights and text.
Because my winter wheels have no sensors and this was easier than breaking them down and putting them in plus I would have to reprogram them twice a year. This was a one time thing, plus if these go dead they will be easier to replace. I have no use for a light to tell me about a tire and I check them once a month anyway. Now I have to worry about 4 going dead instead of 8 but they are easy to replace, I can program them myself, and no taking them to a tire shop.Putting tpms sensors in a tube seems like a wasted effort. If you have functional sensors why on earth would you not just have them put on the wheels where they belong?
So a couple of years ago I watched a guy going down the interstate with a low back tire. Probably didn't bother his handling as he was going straight, fast and it was the rear wheel. It only took a few miles before he blew his tire. Maybe he checked before he left home, maybe he didn't. But a working TPMS probably would have helped him that day. Don't defeat safety measures, they are their for a reason.Because my winter wheels have no sensors and this was easier than breaking them down and putting them in plus I would have to reprogram them twice a year. This was a one time thing, plus if these go dead they will be easier to replace. I have no use for a light to tell me about a tire and I check them once a month anyway. Now I have to worry about 4 going dead instead of 8 but they are easy to replace, I can program them myself, and no taking them to a tire shop.
They went 100 +- years without them and I hate them like many other people do. Yes and the reason is because lazy people never check their tires.So a couple of years ago I watched a guy going down the interstate with a low back tire. Probably didn't bother his handling as he was going straight, fast and it was the rear wheel. It only took a few miles before he blew his tire. Maybe he checked before he left home, maybe he didn't. But a working TPMS probably would have helped him that day. Don't defeat safety measures, they are their for a reason.
This was common(ish) thinking around 2005 or so. TPMS was new tech and you'd get techno-averse types complaining about the vehicle monitoring too much while also complaining about the little yellow light that showed up on the dashboard after they removed the sensors.Putting tpms sensors in a tube seems like a wasted effort. If you have functional sensors why on earth would you not just have them put on the wheels where they belong?
It's actually less effort and read post 35 again.This was common(ish) thinking around 2005 or so. TPMS was new tech and you'd get techno-averse types complaining about the vehicle monitoring too much while also complaining about the little yellow light that showed up on the dashboard after they removed the sensors.
Some people fear change and will put way more effort into doing the wrong thing rather than simply doing things properly.
