tranny stuck in park
HavasuMike
Lake Havasu City, AZ
My wife's 2011 EL won't come out of park. I took off the center cover and was able to push the plastic lock out of the way to get it home, but don't know how to fix the problem. I think there is a solenoid that is supposed to unlock it, but don't know where it is. Left it in neutral, but can't remove the key now.
mrbadwrench
NH
Floor shift or column shift? I just went through this with a 2008 column shift and the part that has that plastic disk you have to move (brake interlock) is only attached with one screw (E4 inverted Torx head) and a clip. I took that out and then replaced the brake light switch. The old switch was bad and the new one was $8 at my local parts store. I'll put the interlock back in when the weather is better.
gixer2000
Retrofit or Bust
Massachusetts
Mine was the same thing.. brake light switch at the dealer was $22.
H
HavasuMike
It turned out to be the brake light switch also. It is a floor shift. Sounds like it may be a common problem. My vehicle has 190k miles on it.
