Transmission Issue?
djock12
Md
Hello, I have 2007 Expy EL (Eddie Bauer) and here is my issue. When I accelerate from a stop the truck tends to make a bump type of noise and the truck jerks and feels as though it will cut off. It's almost like it is trying to find the correct gear. It does this especially if I am starting from the bottom of a hill. I have taken it to a ford dealer and they couldn't find any codes (even though my traction control light comes on). When I turn off the overdrive the truck performs better and doesn't give me the hard bumping or shifting issue.
Has anyone experienced this before? It's really frustrating not knowing what the problem is. It didn't do this when I got the truck and I have had it for about two years now. Any help with this matter would be appreciated.
thanks
FlyBoyd
Las Vegas
thanks
I have a 2008 and was having issues when stopping, I would hear an extra thump. I took it to ford and it took a couple of times before they found a recall they did. There is a method to fix it that they had to do and it went away. I am not sure if this is the same issue, but maybe if you ask ford about it they can tell you what years were affected.
D
djock12
Md
Thanks for the tip. Do you remember the name of the recall?
FlyBoyd
Las Vegas
Unfortunately I don't. I will go through my records to find out what the number was, but I wont be able to do that until tomorrow. It might be quicker to call Ford and ask. If they don't know I can let you know tomorrow night.
FlyBoyd
Las Vegas
Also it wasn't really a "recall" it was more of a fix that I only found out about because I told them to look at the tranny and it was covered under warranty. I have a feeling that the stealership will look at ways to charge then look to the ways that they have to do stuff for free.
Mailman
dfw
I had the same problem and the dealer reflashed the computer and that solved the problem.
mfeezy
Houston, TX
Yeah, rough shifting is a common problem and Ford released a TSB to try to correct this. Just take it in and they should be able to reflash your transmisison control module to hopefully eliminate the issue.
mfeezy
Houston, TX
FYI - I actually just took my 2008 in because of a shifting lag between 1st & 2nd gear and this is what they did per the service order: "Update PCM and TCM time to clear KAM and performed roadtest per TSB 08-22-7". This was all covered under warranty without any issues.
So there's the specific TSB that you can refer them to if necessary. And it seems to have worked for my truck.
jyoungky
Alexandria, KY
Thanks for the info...My 2008 has the same issue. Guess I will be making an appointment...
BlimpinDave
Yes. Have the tranny reflashed. I have an 08 EL XLT.
It is part of the adaptive shifting logic. After a lot of fast acceleration it gets stuck in the fast rough shifting and the byproduct was the thump. I thought I literally dropped my transmission on the ground one day.
The reflash helped but it never would shift right for me. I had the tranny flushed by a competent dealer in Arizona. The one in Wasilla AK only knows how to overcharge for everything. They found it was a 1/2 quart low on fluid. Now it works great.
I almost sold it because of that but thankfully I didnt. It would have turned into an Excursion, so it wouldnt have been all bad.
D
djock12
Md
Thanks for the replies. It actually turned out to be a needed tune up. It was pretty expensive (for a tune up), but the truck is running pretty good and accelerating without issue now.
Tr8rNines
Hampton, VA
I have an issue with my '07 E Bauer with the tow package, where once in a while, after starting it and shifting to any gear, there is a semi-hard bump, then there is a wrench icon light on the dash. The truck will drive fine, except it never leaves 3rd gear. I've put my odbII reader on it but no codes. If I turn it off, then switch the key from off to run 3-10x fast without starting it, like setting up new key fobs, it will clear itself for a while(a week-3 weeks), then it does it again. Has anyone had an issue like this? What's the fix?
jtebbe0529
