My Expy tows a lot. Last trip to Mead was 100*-115* and on steep long grades both the motor and Trans got warm. No warning signs or limp mode but hot. Kept the pedal down to see what happens. Nothing, it recovered as soon as the grade lessened. The 10R80 and new EcoBoost are known to run a little hotter than previous Gens. I ran across this thermal bypass eliminator. Any of you run it? It’s cheap but not sure if it’s worth my time as I have temp swings from below freezing to 100*+ in Utah. It basically stops the Trans from heating up before it opens to the cooler. And does not restrict the flow through the smaller orifice of the stock bypass. Any thoughts?
https://revmaxconverters.com/product/10r80-transmission-cooler-thermostatic-bypass-upgrade/
