Undercoating for rust prevention?
RC Fan
Canada
Hello!
What is the forum consensus on undercoating for rust prevention for those who get lots of snow? We will probably have our ‘18 Expedition for 8 years hopefully, and we would like to protect it from road salt.
Thanks in advance for your assistance!
That’s always a good idea as even though your body panels are aluminum all structural and most drivetrain components are steel. I’m not sure if aluminum corrosion can be stopped with oil based products like on steel. Krown is pretty good at this and spray inside everything but it will drip for a day or so after.
R
RC Fan
Canada
Thanks for your reply!
I can live with the dripping, so no worries there.
NASCAR Mike
Syracuse NY
I would do the Krown oil. In my experience rubberized undercoating will block drainage holes and allow water to accumulate and then rust.
Having lived in Syracuse NY for years I know how bad the snow and all the salt they use can be on a vehicle. I would think Canada is the same.
Here in VA where we don't get much snow, I rinse the underside of my Expy with hot water when I pull into my garage.
lbv150
Northeast
Fluid Film annually. Very effective in rust prevention. Many DOT and municipalities use it on their vehicles. Dealerships offer the service as well as independent shops. We have the capabilities to self spray it and buy in 5 gallon pails.
poppie
Wisconsin
The IDIOTS at the Wisconsin DOT are partnering up with some of the county's to use BRINE in place of road salt crystals on state roads, salt crystals have to dissolve to start eating your RIDE while BRINE will start to eat the moment you get it on your ride not having to dissolve 1'st AND besides that what about the rebar in concrete road's along with all the bridge decking rebar, that concrete DOES get hair line crack's over time allowing that BRINE to soak down to eat the rebar = MORE POT HOLES and then there's the beam's supporting the bridge knowing that they are thick but never the less WHY, then there's the stream's , River's ,Lake's and private drinking water well's , I'm no liberal tree hugger but this is total INSANITY .
NASCAR Mike
Syracuse NY
Brine is only effective in pretreating before a snow storm. It is sprayed on the roads before it starts snowing. It prevents the snow from sticking to the surface. Once it snows localities use a sand / salt mixture. Granted the liquid brine will eventually kick up onto your car.
Every November I wash and wax all of my cars to help prevent snow/salt/sand/brine damage to my vehicles. As I mentioned before, when I drive home after being in the snow I wash down the entire car with warm water. Top to bottom, wheel wells and under chassis. I get the warm water from my sink in my garage. I get out the portable electric leaf blower and blow it dry. Takes me about 20 minutes total.
99WhiteC5Coupe
The road crews in my state also use brine - and a sand mixture. The sand blasts away the paint and windshield glass, when it blows behind a vehicle, and also blasts off the anti-corrosion coating of parts under the vehicle. The sand clogs storm sewers and culvert pipes. When the snow melts, the sand lowers the coefficient of friction of the roadway and extends stoppping distances.
Black
Kentucky
The have been using brine here for at least 5 years and vehicles corrode so much faster since.
I would like to do Krown but closest place is 5 hours away and nothing cool around to make the annual drive worth it.
I’m going to get the Fluid Film DIY kit for $150 which should do both vehicles and just buy a new gallon each year.
Vehicles also get a heavy wax late fall.
Some of my iron parts like the rear diff and axles already have surface rust so I am going to paint them with some rust encapsulater to keep it from rusting and look better.
Gordonzoo
Mass
I too asked this same question on the Lincoln Nav forum and got similar responses. That forum does not have as many visitors so I thought I would hang out on the sister forum :) I too do not have a Krown service close by. I've put Wax-Oil on my 2018 Wrangler and 2016 Ram. It's a one and done application but some here are worried it may clog up drain lines. It's not rubber, its more like a hard wax or Tar. Is it just the AC drain line that I should be concerned about or are there others? I do like how the black looks underneath with Wax-Oil and it does not have to be applied again. You are supposed to go yearly for the panels but I'm more worried about the carriage. I lost my 1997 Ram and 2004.5 F-150. May they rust in piece. I'll not loose another.
