Update all versions of Ford Sync 3 to the latest Sync 3.4
Rob18
Louisiana
Just updated Sync 3.0 to 3.4 now my outside temperature display is stuck at 60 degrees. Any ideas? Could it be caused by something other than the update. I am not sure if it was working correctly right before the update but was working a few days ago.
MxRacer965
Hudsonville, MI
have you rebooted it a couple times? If you rebooted it a couple times did you try a reset?
mcb345
Nashville, TN
Hey all you 3.4 folks. Can anyone jot down some of the larger benefits of upgrading from 3.0 to 3.4? I started reading through the first 10 pages of the thread and didn’t reall gather many answers.
Can you see carplay directions on the drivers display? Does the speed limit pop up next to the digital speedometer? Really are there any meaningful features added or is it mainly just an updated look / UI?
Also I have a CPO warranty and then Ford extended warranty, will upgrading void the warranty for any and all aspects relating to the sync system and overall interior settings and sound system?
Rob18
Louisiana
As far as the external temperature issue. It was my bad I didn't realize that the vehicle needs to be moving for the temp to change.
TheAngryOgre
Reisterstown, MD
MCB345-
Running 3.4 in my new 2021 XLT. Connect the iPhone to the USB jack (either one) and full CarPlay functionality displays. I run Waze for nav and it works perfectly.
mcb345
Nashville, TN
MCB345-
hey, just to confirm you’re saying CarPlay displays on the screen on the driver’s gauge panel above the steering column correct?
TheAngryOgre
Reisterstown, MD
My apologies...did not read your question closely enough. Nothing on driver display, only on the head unit for 3.4. Sorry about that.
Jefes_Shyt
