Updating my sloppy suspension
LovinPSDs
Houston
I’m going to upgrade the suspension in our 2012 step by step until I’m happy with its performance. Right now it’s an absolute mess on the road.
Is the right order the following??
1. Bilsteins
2. Rear sway bar
3. Front sway bar?
Does the order of sway bars matter? Front first, rear first??
Do I need to do full strut assemblies or is shocks fine?
What do y’all think?
JasonH
Houston, TX
Check your control arm bushings. If they are worn replacing the other parts will provide an underwhelming result. Since the vehicle is a 2012, I suggest replacing maintenance items, like struts, control arm bushings, and end links first. Then go for the upgrades, like stiffer tires and sway bars.
GlennSullivan
Yorktown NY & Jupiter FL
If / When replacing shocks and struts be careful if purchasing "packaged units" which come assembled with springs. They are much much easier to change out, however Ford does not make any packaged shock / spring assemblies and the aftermarket frequently gets the spring rates wrong. I replaced all 4 on my 2011 with aftermarket / packaged units and ended up with the front of the truck 1" lower than with the factory springs, giving the truck a severe front rake.
Even though it is harder, I would suggest when replacing shocks and struts replace with the non-packaged units, even though it is much more difficult job,
Also, the front sway bar are these trucks are very large already, not sure if upgrading is necessary. As said above, I'd first focus on all bushings and making sure all fasteners on all suspension links are tight to specs.
L
LovinPSDs
Houston
How do you decipher a good vs. bad bushing? Rot? Is there slop? Or is there a process to properly inspect them?
L
LovinPSDs
Houston
My plan was Bilstein 4600s only. Do I need to replace the actual factory springs back to OEM? Not sure how wore out springs get… also, I’d really hate to be a couple grand into this thing. I do plan on keeping it but I don’t want to put 50% of its value into a repair so trying to be semi reasonable
Roast4570
Upper and lower ball joints for sure, check your Tie Rod ball joints, shocks are a good start, but the real meat and potatoes would be ball joints, control arms, sway bar, tie rod….
GlennSullivan
What I was saying was to NOT replace the factory springs - i.e. even though it is more difficult to replace just the shocks and reuse the factory springs, that is the best approach, provided there are no issues with the existing springs.
ExplorerTom
Colorado
Search youtube for how to diagnose worn suspension components. The videos don’t need to be Expedition specific.
I would start with struts. My Bilstein 5100 are awesome.
Do you have the rear self leveling struts? If so, those springs are bigger in diameter than the non-self leveling springs. So if you are going to swap your springs to new struts, you’ll need to know this. When I did my Bilsteins (need to swap over the spring) I didn’t realize I had the self leveling struts. I had to go to the junkyard to pull struts off a non-self leveling Expedition.
Sway bars. The front sway bar is something like 1.44” in diameter. The aftermarket company (spacing on the name) has a 1.5” diameter sway bar. It’s a lot of money for a minor size difference. The rear sway bar comes in 3 different sizes. I have the largest size and it’s not that much smaller than the aftermarket sway bar.
StephenOsborne1
Southern Idaho
Get a good coil spring compressor and swapping out the shocks using the stock springs is not really tough. Using an impact and the truck on the lift, I can swap all 4 in about 3 hours taking my time. I'd look at sway bar bushings and end links before replacing the stock sway bars. If you tow heavy I might consider a bigger rear sway bar, but not really needed otherwise.
Kng Rnch-Dressing
Having spent too much time on my 2011’s suspension , I’ll second what folks are saying so far. Keep the factory springs.
I’ve used both bilstein 4600 and 5100. Both improve road holding over stock, but some might say the 4600s are on the harsh side of things. They do give the expy great handling though!
Having swapped control arms on several vehicles, I’ve found that the usual “tests” don’t reveal issues unless the bushings are already visibly shot. I have always noticed a difference swapping out 7+yr old arms/bushings though.
If you you’re not noticing clunking/squeaking, you may be able to get away with keeping the sway components (just lube the bushings while out).
Good luck
