Vibration
Firepuppy
Rome NY
I have a 2002 ford expo with 68555 miles on it from florida and when i drive it it has a bad vibration in it i can feel it thru the gas pedal and the truck when im driving about 60 when i slow down it goes away im looking toward either a ujoint for front wheel bearing any suggestions
thanks
firepuppy
toms89
technical advisor
MD
thanks
firepuppy
If you don't feel it in the steering wheel I would consider rear driveshaft U-joint or even rear tire out of balance. Possibly motor balance, cooling fan or flexplate issue. Rotating tires front to rear should make a noticeable difference if tire balance is the issue.
Feeling it in the gas pedal tells me the motor is vibrating. Rear driveline vibrations can be transmitted to the engine. May even look at your motor mounts.
F
Firepuppy
Rome NY
thanks for you reply no its not a miss its a vibration i do feel it thru the steering whhel and the gas pedal any other thoughts
