98nhexpy
My first thought was a bent wheel. But he OP states he changed out wheels with new tires and it didn't correct the issue. If there was a wheel issue, I would have expected the Tire shop to discover that during the "balancing" process.
Given all the information above, did you have the wheels "run-out" on the vehicle? I would be suspect of a failing wheel bearing/hub. Many times that may also display similar symptoms and you may hear a humming sound coming from the assembly at speed.
