1111Expy1111
Alrighty then.
It was painful. But my dayjob involves making sure customers get topnotch service online or on the phone. Ultra Gage failed so badly that I refuse to spend my money with them. Just sayin'.
Alrighty then.
I had this gauge on my '07. Plastic gauge pod Velcroed to the top of the dashboard. Each line can be selected from a long menu. There are also alarms that can be set and flash the red LEDs. I set it to display TransTemp2 and Cylinder Head Temp. The example is displaying Boost and Trans Temp2. The display will automatically cycle thru several parameters if you want to watch more than two. Text LED color is set at the factory. I recall I used green to match the '07 dash. Just plugs into the OBD2 port.
Back in '07 the developers used my Expedition to reprogram the firmware to display trans temp. Flashed a new gauge on the spot in their garage.
Here's my gauge in 2007. (Wasn't monitoring cylinder head temp when the photo was taken.)
Green was too bright at night. Switched the display to red.
-- Chuck
