Lou Hamilton
Maryland
Added the BuiltRight Dash Mount and the 67 Designs MagSafe matte carbon fiber arm.
As an FYI, the new 67 Designs MagSafe doesn’t hold an iPhone 12 Pro Max phone. I had to include the included plate inside my phone cover for a more reliable connection.
Otherwise, it seems great so far. I’ll be using this for the RV GPS (CoPilot RV) app that I am trying out. It is not CarPlay compatible yet. FAQ says they are working on it, but it seems to be a work in progress for some time now.
5280tunage
colorado
After having seen someone mention these in the door ding thread, thought I'd check them out.
Honestly, I am pretty impressed by this seller, at least so far. They were in stock, pre-painted in my color (which is a pretty common color I might add), so they shipped out real fast and I had them on hand in a week. If these things last 2-3 years, for $140, I'm happy. That is, of course, as long as the 3M tape comes off clean enough that maybe I can put new ones on.
Then look as though the are factory made, they are a perfect color match, and took a total of about 30 minutes to install. Washing the car took longer than installing these. During install, I'll say, the flimsy-ness of this things outside door panels came into full light. Just heating the aluminum up to help the adhesive, they popped in and out under light heat from a heat gun. Let alone pressing on the plastic to get it to stick, holy flimsy...
Love them so far! Especially if they help.
EQAddict
Marikina City
Upgraded my stock halogen projectors and foglamps to HI intensity discharge
Add a daytime running light as well that turns amber colored when the turn signal indicators are used.
For some reason i cant attach a picture as the site tells me it is spam.
Sent from my SM-G998B using Tapatalk
lv2drive
PA, USA
which HID kit did you go
with, out of curiosity - for both the halogens & the fogs?
very curious to see if our reflector fogs just scatter the HID light or if the pattern remains tight (mainly in inclement weather conditions / rain / snow etx)
MHay
Finally got around to installing my Sumo springs today. Wow, so much easier than I expected. I didn’t remove the wheels. Jacked up one side at a time, cleaned the springs real good, then put some soapy water on the springs and Sumos. Once I got them started it was easy to feed the rest onto the coils. The hardest part was getting the zip ties in place. I’m towing my travel trailer tomorrow and I’m looking forward to the improved ride!
deh2k7
DWs-TTEB
Evans, GA
@DWs-TTEB what rims and tires are those? What size? They look great. I have a 2018 Limited that want to get black rims and more aggressive tires for.
Are the new tires different size and aspect, and did you need to use Forscan to adjust for that?
check out this thread for my tire/wheel details:
https://www.expeditionforum.com/threads/what-tires-look-good-on-the-expedition.46682/page-2
This model of rim comes in 18” or 20”
Yes I did a tweak w/ ForScan for the larger tire diameter.
Thanks for the complement!
DWs-TTEB
Evans, GA
Lou Hamilton
Maryland
lefty hack
Vegas
Put a 20” light bar in behind the grill
I’m looking for a light bar. Did you look at longer bars? I was thinking 30. Do you think that’d work also? Were you able to make the switch in the cockpit look clean ? I’m worried I’d make it look like a 3rd grader did it. [emoji41]
