MATT0404
MATT0404
NW PA
After 30k miles, my BFG KO2's (OEM Raptor take-offs) were nearing the end of their usable life. Not to mention getting noisy. Wanting to switch it up a bit, I went in a different direction looking for more comfort.
I picked up a set of OEM F-150 Sport wheels that were new take-offs for a great price ($1k shipped). I removed the Bilstein 5100's, adjusted them to the lowest setting, and reinstalled. Mounted up the wheels and tires and this is how she sits now.
I'm happy with the switch. The tires are much more comfortable and quiet. Performance is improved having shed 32 lbs per wheel/tire and MPGs are up. While I was a little hesitant to change it up, it turned out better than I expected. And I still have my old LX-450 (Land Cruiser) for trail duty in the warmer months.
Now to switch out the lug nuts for gray/black and black out the chrome trim. :)
Edit to add: I was fully expecting the rear axles to interfere with the wheel center caps, but they cleared just fine. :shrug:
JAMADOR
Spring, TX
^ Those look great, may have to keep an eye out for some.
Similar to the OE 20s that our Max has, but like the darker shade.
5280tunage
colorado
Regular maintenance stuff, and swapped out my energy suspension generic style swaybar end-links for these guys. They were more of an OE style but heavier duty and I liked that they had grease-able zurks. The only thing was this was third product in a row I've purchased that had zurks that weren't installed by the manufacturer and didn't thread properly. So frustrating, half of the zurks cross threaded, but I managed to get it to work. These felt well made, i know this seems dumb, but they way these were designed, I liked the grease bag - it had these little tiny openings that as you're pumping it full of grease, once it fills up it starts squirting a little bit out.
Link to product on Amazon - https://www.amazon.com/dp/B093QCZP3J?psc=1&ref=ppx_yo2ov_dt_b_product_details
Also added fully sound deadened my lift gate with some 80mil material. I think it helped a bit actually with noise back there and made the lift gate feel little more stout.
AND EDIT - had to pull these dumb TTX end links out, had a terrible popping noise after install, turns out one of the ball joints failed in less than a day. back to the energy suspension universal kit, and no noise. I did replace the bolts though with some new grade8 bolts from Ace. what a mess.
ak49
Alaska
I'm pretty sure the console fridge would fit. We opted for the console safe because we like having a secure place to put my wife's purse, passports, or other vital travel items when on a road trip. We have a Dometic CFX3 25 that we use between the captains chairs in the second row. It offers more flexibility since it's not permanently attached to the vehicle and has more useable space. I don't have it in the vehicle now since it's winter and -10°F. I could throw it in and take a pic if you're interested in seeing what it looks like.
One of the other forum members inquired about the Dometic CFX3 25, so I thought I'd share some picture of how it fits between the seats in the second row.
In the forward position, I can easily reach the bottom of the cooler with my seat slid all the way back (I'm 6'2"). It's a little tippy (forward/backward) in this position due to the floor contour, so you have to shim the front a little.
Our preferred location is towards the back. I can't reach the bottom of the cooler from the driver's seat, but I can easily pull bottles of water out. The armrests have to be up, but it makes a decent armrest replacement for rear passengers especially if you through a blanket or pillow on top to make up for the shorter height. The cooler is much more stable on this section of floor. Having it back further allows for a strap to be ran from the cooler's handle to the child seat anchor on the folded center third row seatback. This stops it from sliding forward during hard braking. We use the other handle to hang a molle dump pouch lined with a doggie bag for trash.
MattG
Toronto
Picked up J&S oil separator for both the SPP and the 5.0. Installing both a breeze; brackets not 100% lined up but a drill made quick work of it.
Cleaned them both up while I was at it.
MTB2022
livonia Michigan
added front auxiliary LED lamps to the front grille with the ford Aeroskin. I hope to add a larger LED down low when I can find a solid way to mount it. Last summer I added the rear work lamps to the rear.
ak49
Alaska
I added a ProClip phone dash mount.
5280tunage
colorado
Pulled this old puppy out and matched my Mishimoto IC with a TurboSmart Veesport vent to atmosphere blowoff valve. Was a little worried about the sound but I can say I love it. Really helps you recognize the power (not in an HP or torque way) of the turbos and just how much air they move. I'm not expecting any real gains, but I wanted to help the turbo surge, and so far I think it's has.
A couple notes. I chose this one because it's plug and play, and also because they actually have a true plug for the standard in system release pipe. Some of the blow off valves out there don't have anything to plug that, they sort of leave it up to you. And I will say, the construction of this unit was awesome. The plug was even bill billet aluminum, which to me is just a sign of good quality. They could have easily handed you some sort of plastic cap to do the same job. Very impressed so far.
Built for anyone else that tries this, I ended up having to use half of the bracket that the blow off valve comes with, and the original bracket from the factory blow off unit. My guess this is some sort of difference between the f-150s and this platform. I would have blamed my intercooler, except the fact that the factory blow off unit directly bolted to that
GixxerJasen
DFW TX
Dang, why isn't this one stickied?
Forgot to take pictures but took off the entire front end in order to replace one small part. I've had the leaking front washer issue and it's frustrating because I fill up washer fluid and then promptly lose half of it. There's a TSB for it, but trying to set aside time when I don't need the truck and can get someone to drive me over to drop it off has been a pain. I've been saying I'd take care of it for six months now, so what the heck, the part is only $20.
I got about halfway through and got frustrated trying to find bolts that are on too small of black and white diagrams that I almost threw in the towel. Glad I didn't because overall it wasn't too bad. I could do it much faster next time.
I tell you though, it's quite stress full yanking the bumper cover off trusting that those pop pins are going to come loose. That's norally nerve wracking but I have a little PTST from removing fender flares on my old 80 series Land Cruiser when I followed directions and found a previous owner had replaced one of the push pins with a nut and bolt, and I yanked hard on it. Ugh. No such drama today. Only managed to lose one of the top push pin things so I need to get a bag of those for the future.
All done and no leaking so far, so looks good.
winksskazam
San Antonio
After having my DIY spray painted emblems on the front grille for 6 months and subjecting them to the Texas Highways (always under construction) they haven’t held up as great as I had hoped. So I replaced them with the OEM ‘23 Timberline Black and Chrome Emblems. I am happy with how they look as the colors I originally chose with my DIY emblems didn’t quite match what I had imagined. Note: it’s difficult to see the difference between the Stock Blue Oval vs. the Timberline Black emblems but in person they are completely different and look 100% better.
apex96
PA
Over the past week I’ve installed NAPA adaptive one vented and slotted front rotors, vented rear rotors and pads all around. Installed Bilstien 5100 shocks on the middle slot all around. Had Method 704s in 17” diameter +25mm offset, wrapped in Cooper A/T3 XLTs in 285/70r17 all around and for the spare installed.
gtr09
Midwest
Finally got busy on mine the last few weeks. Installed or "installed" the following:
Weathertech mudflaps front and rear
Bulletpoint phone mount
Dometic CX25 fridge
Console organizer
Trunk organizer
B&W tow and stow drop hitch
Snatch strap + shackles recovery kit
12v Air compressor
NGK Ruthenium plugs @ .028 gap
CVFab Titan Intercooler (Black)
GofastBits Blow off valve
S&B Cold air intake
J&L catch can
SPD 180 thermostat
ValvoMax oil drain plug
Currently logging revs for a ZFG custom tune with the HP Tuners RTD+. It's a neat little tool and makes the whole process smooth. ZFG is turning around tunes so fast, like a day and no less - very professional! Unfortunately, so far I'm unable to communicate with them. While they respond to my uploads they've ignored every email and text I've sent. Not sure how to actually communicate with them. This last time I left a message in the notes of my log uploaded notification, we'll see.
I didn't get a chance to dyno the car yet, but after the tune is done I'll go dyno it and also the stock tune to see what we get here.
litaz1
hawaii
@winksskazam How did you buy these emblems? I’ve been looking to buy these!
zak99b5
Albany N.Y.
Changed out the atf with my son today. Took a bit longer than anticipated, but that’s ok.
Truck has 71k on it, and not all shifts were great. A lag going into 8th like all the time. Some hard engagement of D or R, and also sometimes a delay when switching between D and R.
Wasn’t too messy, but getting the level correct required a lot more back-n-forth than we thought.
I pumped about 2.5 qts out before we dropped the pan. Still spilled some, but not too much. Figured we got 5.5, maybe a little more out of it. Fluid was pretty damn dark.
Rather than hand-pumping all that in, I ran a hose down to the fill port from the engine bay and poured in 5.5 qts.
In the end, it took 7 QTs to get it up to a decent level. Tranny was at about 130* by the time we were close, and we were about 1/3 of the way into the space between 6 and 5. It may be a little overfilled, but I guess we will see.
But it seems pretty clear that it was underfilled before. On the test drive it shifted fine, and the 1-second long hesitation before 8th engages is now just a little blip.
Left Coast Geek
Mid Left Coast
What I did with my gen4 Expedition this week? I bought it night before last, and drove it home!
past that its been reading the owners manual and checking things out. flash updating the sync3, doing a master reset and reprogramming stuff, etc.
2019 Expedition 4x4 Limited Stealth
Illinois
New to me 2019 Expedition XLT
Painted front grill black and body color
Chrome delete + Gloss black side mirrors and door handles
White Expedition emblem on the tailgate
Stealth Expedition lettering on hood
Removed XLT emblem on tailgate
Powdercoat 20” stock wheels in gloss black
New Pirelli Scorpion WeatherActive tires
Caliper covers in Electric Blue (the color of my first car, a MINI Cooper S)
Weathertech scratch protection
Tuxmats on all three rows
Half safe for center console
All new speakers plus 18 inch subwoofer and amp
Catalytic converter shield
LEDs for all exterior lights
Tints all around
Medium tint on headlights (which have since been removed —dimmed the lights more than I expected)
Next on the list:
Painted Ford emblems front and rear
Rear view mirror camera
Custom black paint on taillights
Black out headlights and demon eyes
Touch-up paint on bumpers
Love the car and love that I’m making it everything I’ve wanted!IMG_2117.jpegIMG_2124.jpeg
No members online now.
Landsbutter
