Would this RC lift fit on my 98 Exp?
Thermo
technical advisor
Will work for the front, but you still need to take care of the back. Granted, I would look at the parts and see what sort of metal the kit is made from. It looks a little thin from the pictures. The parts should be made from welded 1/4" plate. If they are made from 1/8" steel plate that is bent in a form, run from the kit unless all you plan on doing is driving the truck on the street.
DR3W
L.A. - IE/SoCal
A 5 inch front lift. For a good stance. Probably 3' rear lift for a 4x4. Depending on preference.
and +1 thermo
Expeditionary
Tampa, Florida
If I remember correctly looking at pictures of your rancho "Lift Kit" lol you had air suspension up front?
Use the search feature and search "finally done" thats the reason mine isnt sitting 6" taller than it is now... That and the $$$ lol.
Im thinking about doing one of these RCX F150 lifts and just using the front parts on my truck. Gotta get the cash and get my buddy to help fab it up to work with my suspension first
